Old 12-29-2013, 08:42 PM   #31
dhagin
Originally Posted by Louis
So what does that mean for my project?
Don't listen to cheery CX.
More boards.
dana
Old 12-30-2013, 11:28 AM   #32
by-eye
CX failed to tell you to bleed out in the tub, less mess.
Here's a link to the boring guide.
http://www.tileyourworld.com/constru...oringGuide.pdf
Are you doing this with a permit? If not I wouldn't worry. If so, you will have to meet those guidelines with the drain or reroute it. I would try to map that electric too. Code would require a dedicated 20 amp circuit for your GFCI receptical(s).
BTW, those americast tubs are only 100 lbs, and not bad IMO
Keep us posted.
Mark
by-eye is offline   Reply With Quote
Old 12-30-2013, 12:15 PM   #33
Mathelo
Keep us posted.
Mark,
But the tub is gone ...
Thanks for the link. That boring guide is helpful.
The drain will have to run through the floor joists but I'll make the holes 2". Either that or I run it down the exterior or interior wall to the basement and hook into a drain pipe there. Would not be an easy project but doable.
The bores are 2 ft from the outside wall, just on the edge of the 2/3rds center that needs to be sistered. Would I gain anything by moving them closer to the outside wall? Drilling more holes - even after putting in the sisters - seem like I'd be going the wrong direction.
I keep reminding myself that this structure has been in place for over 50 years. Seems to be holding okay.
I'll be mapping out my electrical. I'm also putting in a Nuheat mat, which I understand requires its on circuit.
Permits? What are those?
Louis
Mathelo is online now   Reply With Quote
Old 12-30-2013, 12:19 PM   #34
Mathelo
More boards.
Dana,
Yes, that is the plan. Do you think this now calls for full span sisters? Or suppose I place the sisters in the middle 2/3rds as planned, which takes them just to the edge of the bores. Then sister the other side over the bores from the outside wall overlapping the bores by 2 to 3 feet. Any benefit in that?
Would I gain anything by using LVL for the sisters?
Louis
Old 12-30-2013, 12:26 PM   #35
Mathelo
Originally Posted by CX
There's just not a hellofa lot a fella can do in situations like that except to provide additional support under the joists if that's feasible. Otherwise you just hope that's a really nice joist and manages to remain sufficiently rigid, I suppose.
Additional support under the joist is not feasible without sticking a column in the dinning room.
It has been in place for over 50 years and seems to be holding strong. Nonetheless, I need to beef it up for the tile.
Looks like it's too close to the holes for the wiring, too.
Which wiring holes are you referring to?
Louis
Old 12-30-2013, 12:47 PM   #36
dhagin
The notching and boring guide is derived from extensive testing by the lumber industry, and once you exceed hole/notch size/location, the joist no longer functions as a joist according to code.
So, that means you need 2 sisters, unless the notch/hole is closer to the end then you'd need a new full length joist + 1 sister. Other options, which I'd consider were this my project, would be (1) 3x joist or some type of engineered joist instead of 3 partial joists cobbled together.
Make sense?
dana
Old 12-30-2013, 01:13 PM   #37
by-eye
This is just opinion, and not pro advice.
Since you deflection is not bad, and your not doing a permit, I would consider some options. Sistering is going to be a big job when you get into that electric. Read http://www.johnbridge.com/vbulletin/...ad.php?t=57494 alternative for ideas.
Use 3/4 BC t+g ply, imbed the nuheat in SLC, and use uncoupling membrane, and you should be ok. You can also get reinforcement steel for the pipe holes.
Mark
Old 12-30-2013, 01:52 PM   #38
Bodie Powers
Retired cabinet maker/remodeler
I'd sister both sides with 2x lumber....and I'd run the sisters well past the drain hole, all the way to the adjacent wall. There's no reason to limit the sisters to "center two-thirds"; more is better in your case. If you drill new 1-3/4 holes centered over the existing hole, how close to the edge would the new holes be?
No need for a utility knife.
Bodie
Bodie Powers is offline   Reply With Quote
Old 12-30-2013, 03:51 PM   #39
Mathelo
Edge of the joist or edge of the room?
Joists are 2x8s so approximately 2.75" from joist edge with 1.75" holes. If I re-drill at current location after installing sisters the holes are approximately 2 ft from the outside wall. In theory, I could move the drain all the way to the outside wall edge with some modification to the trunk tie-in.
Louis
Old 12-30-2013, 04:04 PM   #40
Bodie Powers
Sorry....let me try again. If you sister both sides with 2x8's and then drill 1-3/4" holes that are centered over the existing 2-1/2" hole, how far from the sistered joists edges would the new 1-3/4" holes be? Make sense what I'm asking?
In addition, I would extend the sistered joists as far beyond the drain holes as possible....IIRC you said the holes were about 2' from where they're headed off at that side wall....so you'd run them ~2' past the holes.
I wouldn't move the drain line to a new location beyond where the sisters end.
Bodie
Old 12-30-2013, 04:52 PM   #41
Mathelo
If I'm getting what you are saying, the end of the sisters would just reach the holes unless I extend them further. They do not overlap the holes. I'm guessing I need to adjust this part of the plan.
Louis
Old 12-30-2013, 05:10 PM   #42
Bodie Powers
Yes, I'm suggesting extending the sisters well past the drain holes....the theory being that it's better to sandwich them between 2 properly drilled sisters. I'm not a structural engineer and I can't prove my theory, but in my mind it makes sense to do it that way.
Bodie
Old 12-30-2013, 05:28 PM   #43
Mathelo
This is the original idea.
Name:  12-30-2013 5-58-43 PM.jpg
I believe this is what you are proposing, correct?
Name:  12-30-2013 6-21-23 PM.jpg
Louis
Old 12-30-2013, 05:45 PM   #44
Mathelo
So given all this effort I'm starting to think I'm better off just ripping the sheet rock out and running 'single' sisters full length or would I still have to double up on the sisters?
Also, regarding the plumbing, the only way I'll get the new PVC installed is in pieces. I'm assuming / hoping that is okay.
Louis
Old 12-30-2013, 06:31 PM   #45
Bodie Powers
Louis, yes that second graphic was what I was suggesting. As I said, I'm not a structural engineer and cannot provide supporting algorithms. Maybe just single sisters, but extending to the side wall, would be sufficient.
I still don't get why ripping out the ceiling is going to make this any easier. You appear to have access from the top to nearly 10' of the 12' joist span.
Not sure what you mean by "the only way I'll get the new PVC installed is in pieces". As long as your PVC meets code requirements for slope/size/, and your couplings are appropriate for the application and are properly assembled/glued per mfg specs you're OK.
Bodie
Peggy's Upstairs Bath Peggy Donahue Tile Forum/Advice Board 124 07-03-2011 06:30 PM
changing upstairs bath changes4U Tile Forum/Advice Board 12 02-21-2010 11:07 PM
Upstairs Bath Remodel GeraldF Tile Forum/Advice Board 1 01-21-2010 09:30 PM
Remodeling Upstairs Bath KeithE Tile Forum/Advice Board 3 02-09-2006 10:40 PM
Upstairs laundry and bath Unregistered Tile Forum/Advice Board 5 08-29-2004 07:45 PM
