Old 02-05-2018, 10:52 PM   #181
Wall ... floor... its all the same.
Just rotate the picture 90.
Old 02-06-2018, 07:38 AM   #182
Have you laid out the wall tile to see where the holes would fall?
If I were faced with that challenge I'd get the tile as far inboard of the toilet perimeter line, around the large holes, and drill the smaller holes for the mounting studs. Maybe cut the tile in half across the hole then use a saw to remove each half round portion. It's not as though the back of the toilet is a continuous, uninterrupted plane. As long as you have the bearing points sufficiently supported it'll be fine.
Caulking wise, I only mentioned it because my own preference is thin joints for as little caulk as possible. Given that tile profile you're already going to be a little challenged to get a clean caulk, not to mention grout, line.
Was just curious if your Geberit has a small hose coming out of the top of the fill valve. Mine appears to have the nipple for the hose, but no hose.
Old 02-06-2018, 02:12 PM   #183
Mathelo
Originally Posted by Houston Remodeler
Caulking the terlit to the floor is required by code in Texas. We are old school and like to leave a 2 inch gap at the rear of the terlit to allow any water to escape and show a leak. If it never leaks, the gap will not matter.
I like this idea. Works even better with a wall hung toilet.
Louis
Mathelo is offline   Reply With Quote
Old 02-06-2018, 02:29 PM   #184
Mathelo
The wall behind the toilet will take a little over 4 tiles. Each tile is 8" wide. If I try to make this work with minimal cuts to the tile, the tiles will meet close to the center line of the toilet. If I understand your suggestion, I should try and get a full tile down the center of the toilet. As the attached baseboard shot illustrates, that would put the large holes in the panel and the smaller holes on the edge of the panel. This would allow me to cut the panel in pieces for the large holes. Is that what you are suggesting?
I'm not entirely sure what you are asking on the Geberit. I assume you mean inside the tank? I'll have to take a look. I haven't had it open in awhile.
Louis
Old 02-08-2018, 08:28 AM   #185
If, for instance, you have a tile that is dead centered over the large holes. I would cut that tile in half horizontally across the center of the top hole, and again for the bottom hole. Draw the 4 half circles on the cut tiles, use your wet saw to make a bunch of cuts to the half circle line - maybe an 1/8" or so between each cut, chip out the left over bits. You're left with an ugly, but effective half circle - which no one will see. Can do the same process if the holes fall on the long edges of the tiles.
Ya know how a traditional toilet fill valve has a small hose attached to a nipple on the top, and that hose squirts water into the vertical fill tube in order to replenish the water in the bowl? The Geberit fill valve appears to have one of those nipples, but no hose attached. Was curious is yours does.
Old 02-08-2018, 02:04 PM   #186
Mathelo
I'll have to take a look but I don't recall any hose but I don't remember the nipple either. Maybe I just didn't inspect it closely enough.
Louis
Peggy's Upstairs Bath Peggy Donahue Tile Forum/Advice Board 124 07-03-2011 06:30 PM
changing upstairs bath changes4U Tile Forum/Advice Board 12 02-21-2010 11:07 PM
Upstairs Bath Remodel GeraldF Tile Forum/Advice Board 1 01-21-2010 09:30 PM
Remodeling Upstairs Bath KeithE Tile Forum/Advice Board 3 02-09-2006 10:40 PM
Upstairs laundry and bath Unregistered Tile Forum/Advice Board 5 08-29-2004 07:45 PM
