Old 12-15-2017, 02:54 PM   #136
Mathelo
I'm installing this herringbone marble tile that measures 1" x 3" over Ditra Heat.
I'm planning on pre-filling the Ditra Heat with MAPEI Porcelain modified. I'd like to use the same to set the tile because of the extra strength and the fact that the 1" x 3" tiles are out of spec with Schluter's published requirements even though they told me it is okay. They did recommend setting the tile with an unmodified mortar but given that these tiles are as small as they are, I can't imagine that drying time will be a big issue.
What do you think?
Louis
Louis
Mathelo is offline   Reply With Quote
Old 12-15-2017, 03:19 PM   #137
rmckee84
I wouldn't have a problem using modified to set it, but make sure and use a white thinset. I don't use that particular thinset so I cant speak to its performance over ditra heat or with marble.
You have to be careful prefilling over ditra heat, sometimes while kneeling after it's prefilled the thinset will pop out of the little nubs the wire seats around.
Ryan McKee
Old 12-15-2017, 03:44 PM   #138
Mathelo
Yes, white is in the plans.
I've used Laticrete in the past but this is easier to get at Lowes. It is suppose to be equivalent to Mapei UF2.
Thanks for the pointer on pre-filling. I'll be extra cautious after it is filled.
Louis
Old 12-16-2017, 06:34 PM   #139
mark999
Did you pour a slc as a base for the ditra heat? It is recomended to have the floor flat before installing ditra.As far as thinset goes If you can get Latticrete products I would use their trilite. It is designed for LFT and non sag but works great on all kinds and sizes of tile. Use a wood beating block and or a rubber float to embed and level your tiles. then check with the feel of your hands.If you do not use to big of a notch trowel you should not get hardly any ooze out of thinset into joints. But keep a toothbrush handy in your water bucket. On the other hand make sure you are getting proper coverage with the thinset(pull 1 or 2 sheets and check when you start out. And I would seal all the marble tile and let dry prior to setting.
Mark
Old 12-16-2017, 07:22 PM   #140
After you fill the Ditra Heat, check the floor for small valleys and humps. If you walked on the Dita Heat after you put it down, sometimes the thinset will mash under the Ditra causing a low spot. I have found this to be a problem with regular Ditra more than the Ditra Heat mat but it might be worth checking. The reason I mention it is because the small tiles will follow any flaws in the floor. Doesn't cause as much of a problem when using larger tiles over Ditra.
Old 12-17-2017, 09:16 AM   #141
Mathelo
Mark
I did not pour slc because the floor is almost an inch higher at the hallway than the outside wall. The slc would have resulted in too large a transition. I have spread MAPEI Uncoupling Membrane Medium Bed mortar using a homemade screed board to get it level. A real pain in the ass but I'm hoping good enough. After laying the Ditra Heat I'll check again for low spots.
I have set small tiles before, a basket weave,
http://www.johnbridge.com/vbulletin/...d.php?t=104690
and they are truly a pain but that is what the wife wants.
Louis
Old 12-17-2017, 09:18 AM   #142
Mathelo
Thanks for the pointer. Will do.
Louis
Old 12-24-2017, 09:08 AM   #143
Mathelo
Question Waterproof the floor or not?
I'm trying to decide whether to Kerdi Band the room perimeter and the seams in the Ditra. I tend to overdo and I'm thinking this is a case of that.
This is a typical bathroom with a tub and overhead shower. I will be tiling up the walls.
The likelihood of water at the perimeter seems unlikely but of course it will happen at some point. Is this enough reason to Kerdi Band the room and floor?
Louis
Old 12-24-2017, 10:40 AM   #144
rmckee84
Necessary, no. But it certainly won't hurt anything.
Ryan McKee
Old 12-24-2017, 11:35 AM   #145
Mathelo
But do you think it is worth the effort? Would you do it?
Louis
Old 12-24-2017, 12:41 PM   #146
I do it all the time, but then we are over the top , OCD nut jobs.
Old 12-24-2017, 01:01 PM   #147
Mathelo
Sadly I can relate.
Louis
Old 12-30-2017, 11:59 AM   #148
Mathelo
Trowel size?
What size trowel would you use with this 1" x 3" herringbone tile? I'm thinking 1/4" x 3/16" v-notch.
Louis
Old 12-30-2017, 07:04 PM   #149
Sounds about like the right size. I'd check the floor with a straight edge. Those small tiles will follow every hill and valley.
Old 12-31-2017, 06:13 AM   #150
Mathelo
Yea, I know. I'm spending lots of time making sure the floor is level.
Louis
Peggy's Upstairs Bath Peggy Donahue Tile Forum/Advice Board 124 07-03-2011 06:30 PM
changing upstairs bath changes4U Tile Forum/Advice Board 12 02-21-2010 11:07 PM
Upstairs Bath Remodel GeraldF Tile Forum/Advice Board 1 01-21-2010 09:30 PM
Remodeling Upstairs Bath KeithE Tile Forum/Advice Board 3 02-09-2006 10:40 PM
Upstairs laundry and bath Unregistered Tile Forum/Advice Board 5 08-29-2004 07:45 PM
