Old 10-17-2013, 07:21 PM   #1
elduderino
Quartz Floor Tile Install - Total Noob
So I'd like to install quartz tile in my dining room. I've done as much research as I could find online about how to install it, but it still scares me. (I must DIY it, otherwise I would pay for it to be done if I had the cash) I found the 24 x 24 tile for $2.50 a sq ft at habitat for humanity restore, so I can't really beat that. Room is 185 sq ft if that matters.
From what I read, I should thin set the plywood, apply durock over it and screw it down. Tape the seams with fiberglass tape, and thin set the seams. That's what I have for the prep part.
As far as the actual install, I'm seeing I should not be using thin set, but instead being using an epoxy to lay the tiles. While I have never laid tile on a floor, my father who's helping me out has done quite a few, but all being ceramic.
Any advice or tips would be HUGELY appreciated. Even if they consist of, "Dude, you're gonna mess it all up". I'd rather know now, than when it's tool late and I'm stuck with a screwed up floor.
Jeff
elduderino is offline   Reply With Quote
Old 10-17-2013, 07:44 PM   #2
Welcome, Jeff.
First consideration is that you're dealing with a natural stone tile and you should first ensure that your floor structure and subflooring are adequate for the application. While ceramic tile installations over wood framed floors require a deflection in both joists and subfloor of L/360 or less, natural stone requires L/720 or less, a far, far more rigid floor.
And natural stone tile requires a double layer of plywood or OSB subflooring regardless the joist spacing.
That's the first thing you need to be checking and correcting.
Over that subflooring you can add a CBU (your Durock) or other tiling membrane and tile. Read and follow the manufacturer's installation instructions for whatever tiling substrate you choose.
Second major consideration, and one you'll want to incorporate in your subflooring upgrade, is that your floor must be very, very flat to accommodate those large format tiles.
The tile industry standard for substrate flatness for tiles that size requires no deviation from intended plane of more than 1/8th" in any 10 feet and no more than 1/16" in any two feet. That is an extraordinarily flat floor and you're gonna find that you'd really like yours to be better than that.
I would strongly recommend you also invest in a mechanical tile flattening system to aid you in setting those tile without excessive lippage. There area a number of such systems on the market. Two that spring to mind and with which we (TYW in general) have a good deal of experience are the TLS and the MLT, each of which have a great deal of feedback here on the forums.
Those big stones are not for sissies.
Old 10-17-2013, 08:15 PM   #3
PetrH
In addition to what CX said, you don't need epoxy to set Quartzite. What you need is a modified Medium bed mortar, or a thinset mortar designed for large format tiles.
Petr
Old 10-17-2013, 08:47 PM   #4
Arizona Floors
ReTile
Arizona Floors's Avatar
I've been seeing granirapid mostly specified for Quartz tiles. I've also seen huge jobs fail, around the 5 year mark, from using regular modified thinset, they were completely unbonded. Quartz moves way too much to bond with regular thinset.
Granirapid
Last edited by Arizona Floors; 10-17-2013 at 08:52 PM. Reason: correcting the link
Arizona Floors is offline   Reply With Quote
Old 10-18-2013, 04:46 AM   #5
elduderino
So with the Granirapid, do I need the 2-part version, or just the "white"? Also do they sell this at home depot or lowes, or do I need to find a more specialized store? (I assume ... or not, I can't put links in my post. Think I found it on the lowes site ) Will the 1 bag cover 200 sq ft?
The Tuscan leveling system looks pretty awesome, I have to say.
Jeff
Quartz ledgestone install fshead Tile Forum/Advice Board 5 12-30-2012 01:15 PM
advices seaking noob ..concrete floor prep for stone install JinMTVT Tile Forum/Advice Board 41 09-15-2010 10:28 PM
Noob installing a slate tile floor TrevorD Tile Forum/Advice Board 12 03-20-2010 08:04 PM
Star Quartz - Quartz Lock defective product homeownerbayarea Tile Forum/Advice Board 4 10-08-2009 11:19 PM
Shower tile floor repair by total newbie... :D Kaeri Tile Forum/Advice Board 2 06-17-2009 08:46 PM
