Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Tile & Stone Forums > Reference Liberry :-)
Closed Thread
Old 06-26-2013, 06:17 PM   #1
dhagin
Codes & Code Approvals: Building, Plumbing, Mechanical, etc.
Below is the link to the I-Codes available online for free.
Let us know if you find any other code links online, or if you find a bad link. We'll try to keep this up to date. Thanks.
Indexed by State
https://codes.iccsafe.org/public/
dana
dhagin is offline
Old 08-05-2013, 12:58 PM   #2
dhagin
ADA stuff
Below are links for ADA info, with references and drawings to help explain it all.
Main page:
http://www.access-board.gov/guidelin.../ada-standards
Bathrooms:
http://www.access-board.gov/guidelin...and-facilities
Showers:
http://www.access-board.gov/guidelin...20Compartments
dana
dhagin is offline
Old 09-16-2013, 08:37 AM   #3
Durock Shower Code Listings
We have all of the pertinent listings and approvals and are in the process of putting them on the website. I've attached the pdfs of our listings, and links to the IAPMO website where they can be found as well. 0008287 & 0008288 are for the drain and 0008312 is for the shower kit.
http://pld.iapmo.org/file_info.asp?file_no=0008287
http://pld.iapmo.org/file_info.asp?file_no=0008288
http://pld.iapmo.org/file_info.asp?file_no=0008312
cx is offline
Old 09-16-2013, 08:42 AM   #4
Kerdi and Ditra Code Approvals
Here are links to the UPC certification listings for Schluter's Kerdi and Ditra membranes, AND the Kerdi-Drain.
Additionally, here is a current International Code Council (ICC) evaluation report detailing the use of both Ditra and Kerdi as a waterproofing membrane. The report is dated August, 2011 and is subject to renewal in two years.
In summary, the use of Ditra and Kerdi as a waterproof membrane is in compliance with the International Building Code (IBC), the International Residential Code (IRC), and the International Plumbing Code (IPC).
cx is offline
Old 12-26-2014, 07:17 PM   #5
Tiger Mountain Tile Inc
tile lackey
Laticrete Shower Drain Approval
http://www.johnbridge.com/vbulletin/...9&d=1349190231
Jim Upton
DIYTileGuy
Tiger Mountain Tile Inc is offline
Old 02-20-2015, 09:41 AM   #6
Elamhome
Codes: Building, Plumbing, Mechanical, etc.
I came across the following resources while conducting research for my master bath renovation. I did not see these links in the Codes reference thread in the Liberry and thought that they may be useful for others looking for copies of the various building codes.
The following link at Public.Resource.org contains a table with codes adopted by each state and links to PDF versions of most codes:
https://law.resource.org/pub/us/code/safety.html
An additional source for this information is Archive.Org. The files located here are not as well organized as the previous link, but some of the codes listed here are available in alternate formats including Kindle and EPUB.
https://archive.org/details/publicsafetycode
Jon
Elamhome is offline
Old 11-28-2016, 01:25 PM   #7
tile lackey
I use this guy's site when I need to look up code clearances for bathrooms and such. Plus there's picutures!
Jim Upton
DIYTileGuy
Closed Thread
HTML code is On
Coastal Building Codes Hammy The Mud Box 1 01-12-2012 04:53 PM
Plumbing Code cx Professionals' Hangout 2 04-04-2011 11:15 AM
plumbing code wi_rookie Professionals' Hangout 26 08-11-2009 09:11 PM
Building Codes dhagin Professionals' Hangout 2 03-27-2009 05:13 PM
Kerdi, sheetrock & the Plumbing codes? LazyPup Tile Forum/Advice Board 4 09-20-2005 09:46 PM
