Old 05-27-2013, 09:38 AM   #1
EricO
EricO
What size trowel to use for 6x24 porcelain?
I was thinking 1/4 by 3/8ths.
Maybe 1/2 by 1/2? Is that overkill?
I like Ultraflex 3 for floors. Is that overkill or worth the extra money for peace of mind?
Maybe Ultraflex 2??
The deflecto checks out and we are going over two layers of 3/4 ply and half inch of Durarock set in custom brand thinset. Should make for a sturdy floor but I'm the paranoid type.
What do you pros like to use on porcelain floor?
Eric
EricO is offline   Reply With Quote
Old 05-27-2013, 11:40 AM   #2
evan1968
Not So Senior Contributor
evan1968's Avatar
Hi Eric!
Half by half notch will work for you. Wouldnt go any less than 3/8"x3/8" Give the backs of the tile a thinset skim coat(flat side of the trowel.Like buttering bread) before you set the tile. You are insuring a good bond that way.
A good modified thinset is what you want. I personally like Laticrete 253 Gold.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
evan1968 is online now   Reply With Quote
Old 05-27-2013, 03:00 PM   #3
Eric, don't get caught up in worrying about the notch size of your trowel, and keep your eye on the goal of achieving as close as possible to 100 percent coverage on the back of each tile with a minimum thickness of 3/32nds of an inch when they're set. The absolute minimum requirement under industry standards is 80 percent coverage with good coverage under all edges and corners.
If your tiles are flat, and your substrate is flat, your 1/4"x3/8ths" notch might be more than adequate. You'll wanna be keying in mortar to the back of each tile anyway, and that will help. If you can't get the required coverage with what you've got, you might need to adjust your technique or your trowel, or both.
The coverage is what's important, not what you used to get it.
Old 05-27-2013, 03:38 PM   #4
Hi Eric, especially check the center of the tiles. The long tiles tend to be cupped and you may have good thinset coverage on the ends and skimpy in the center. You may have to add a little in the middle of the tiles.
Trowel SIze for 20" Porcelain Briyon Tile Forum/Advice Board 3 10-13-2010 04:53 AM
Rialto porcelain tile trowel notch size huggins Tile Forum/Advice Board 4 02-18-2008 09:15 PM
18x18 porcelain tile trowel size and thinset? cra Tile Forum/Advice Board 8 03-20-2006 02:40 PM
Trowel Size Hipple Tile Forum/Advice Board 5 07-06-2004 10:06 AM
trowel size--grout size jflm Tile Forum/Advice Board 1 01-22-2003 05:50 PM
