Old 03-09-2013, 09:06 AM   #46
Mick,
since Jon doesnt see the need for a new system,
can you re-route his package to me?
Old 03-09-2013, 09:09 AM   #47
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Originally Posted by Ernie
We have no detonators within the straps
Nahhhhh, I WANNIT!!
Bill
Old 03-09-2013, 09:49 AM   #48
T_Hulse
Tile Contractor
T_Hulse's Avatar
This sounds much better than a good MLT (mutton, lettuce, tomato) sandwich.
I'm curious how the strap releases from the plate? Is it just by applying more pressure to the gun, like TLS? If so, would that make the straps only last for a few uses before they release too easily when tightening straps? How many uses have you been getting out of the straps?
I sure like the big foot for leveling. Also, only having to replace the plate will hopefully make this more economical for almost every job.
Congratulations Mick.
Tom Hulse
Visit my web site here
Old 03-09-2013, 09:59 AM   #49
The Kid
The Kid's Avatar
To me the bases look the same for porcelain and thin tile, and the plank and stone plates look the same too. I'm sure there is a difference, care to explain?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Old 03-09-2013, 10:02 AM   #50
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I'd like to hear more about the plates myself
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Old 03-09-2013, 10:17 AM   #51
Art of Stone
VP of Technical and Training MLT System
Art of Stone's Avatar
The "Thin Tile Plate" is smaller and made of a more plyable material than the "Porcelain Tile Plate"; not as rigid.
It is also thinner than the plate for Porcelain.
The "Stone Plate" is also more rigid than the plate for "Planks".
Ernie
Lay 'em Right
“Vision without execution is hallucination.”
― Thomas A. Edison
http://www.mltsystem.com
Art of Stone is offline   Reply With Quote
Old 03-09-2013, 10:24 AM   #52
Art of Stone
For the sample batches that went out, the plates should be soaked in water prior to installing.
The factory is setting up a hydration system for future production to allow installation without having to pre-soak the plates.
Ernie
Lay 'em Right
― Thomas A. Edison
Old 03-09-2013, 10:27 AM   #53
Chad Deiter Company
No pre soak would be awesome. Just use them right out of the box.
Old 03-09-2013, 10:29 AM   #54
Life Span of the Straps
The stainless part of the strap has holes that go over protrusions on the base plate. If you over tension them they will shear through the plastic and you'll have to start over -- just as with the TLS.
The straps will last indefinitely, probably as long as the caps or longer, and the caps will last until you drop your tile saw on them and crush them.
As to JB, CX and Dave M keeping secrets, we are lucky to be at the center of things in the industry. Our tight lips keep us there. There are more surprises in your future, but that little birdie ain't talkin' at all.
And no, JB Forum is not Mick and Ernie's third partner. That entity prefers to remain anonymous at this time. We will happily accept advertising money, though.
Old 03-09-2013, 11:00 AM   #55
I made an estimate that I will be saving a good amount per 500 uses.
Old 03-09-2013, 11:27 AM   #56
pgc555
I read through the thread quick, can I assume theses will be at Coverings for the world, and us to see? Any possibility to connect picking up our JB Forum shirts and a sample bag of these at the same time at the show?
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Old 03-09-2013, 12:27 PM   #57
Art of Stone
I do expect our presence to be known at Coverings though i've heard no mention of sample bags, Phil.
Ernie
Lay 'em Right
― Thomas A. Edison
Old 03-09-2013, 12:32 PM   #58
Cain
Cain
Don't let him make any promises Phil. Im still waiting for my shirt from the last Co.
Looks like a good system, cant wait to give it a try
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Old 03-09-2013, 12:37 PM   #59
Topspin
SchluterUgrad
Topspin's Avatar
OK Brian, sounds like you know more than we do. What's the scoops?
estimated a good savings on 500
How much savings? And to figger savings you must know approx $$. So give it up. How much for straps, caps and footies?
With such a large surface area on the caps, will they clean up easily? Get a little 254 on them and their cleanable or toast? In my bag of current TLS caps you'll find maybe 5-10% have some t/s on the bottom of the caps, so a concern is t/s on those big flat surfaces. Tile scratcher if not pristine?
What about the squeeze-out I get under my caps/or at least right at the strap breakpoint between tiles. (Yeah, I know it's a personal problem, but we all get it once in a while) If you get a wad of modified on that pretty little SS connector will it be useable again without jewelers tools for cleanup?
I love my current TLS but this MLT looks mil-spec tough. Definitely worth considering. Once the evaluation kit arrives I'll issue my report.
Old 03-09-2013, 12:40 PM   #60
Bill Vincent
Tile Contractor
he's special.
Bill
Tile Leveling Systems Plumbline Tile Forum/Advice Board 8 12-21-2011 09:35 AM
fat mud on plaster and leveling systems asutterer Tile Forum/Advice Board 3 11-09-2011 10:38 PM
Self-leveling countertop system for ceramic tile Dale Watnee Professionals' Hangout 34 02-17-2002 10:47 PM
