Old 03-08-2013, 08:15 PM   #16
The Kid
The Kid's Avatar
So when and where can we get these?
Other then the waste factor and the base for soft stone, why would these be better then Tls?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Old 03-08-2013, 08:26 PM   #17
Lump
Lump's Avatar
Now I can add this system to the mix of the lash/TLS/tornado system that we already have. So it's a three piece unit. Is it faster than TLS?
Brad L. Lenz
NTCA Proud Member
Old 03-08-2013, 08:32 PM   #18
Okay, now I'll tell you that the caps for the pro version are being re-worked. Instead of going across the joint as they do now they will be turned 90 degrees . . . the long side will parallel the joint. We won't have pictures of the new cap for a week or so.
Everything is made in Italy for the MLT company which is owned by Mick, Ernie and a third partner.
The thin portion of the straps are ss, and Brian has it right . . . 1/64 in. thick. There are two holes in the metal that go over little plastic knobs on the foot thingys. The plastic shears off and the entire strap is retrieved.
For the pro series there are ss inserts that go into the caps that will extend their life almost indefinitely. I don't know yet what the final price will be to pros, but the number of parts that must be re-purchased is 1 -- the little foot thingy. That makes the MLT system the least expensive of them all on a permanent basis.
There are several different base plates to accommodate different types of tile. There is also a rubber bushing that protects delicate tiles (polished stone) from being marred by the plastic caps.
Everything has been thought of. The caps can be removed at any stage without forfeiting any parts. There is a slot in the side of the cap that allows you to simply move it sideways to disengage it from the strap.
Mick and Ernie will find this thread and answer in depth questions.
Old 03-08-2013, 08:32 PM   #19
I think a lot of questions will have to be answered after guys get them and start using it.
I really like this feature of the system.
Old 03-08-2013, 08:35 PM   #20
Riiiiight.
Old 03-08-2013, 08:37 PM   #21
The little foot thingys otherwise known as base plates.
Old 03-08-2013, 08:38 PM   #22
The Kid
The Kid's Avatar
I'm ready, send some my way!
Nice tyw gun!
Man, all that stuff looks pretty intense.
Jeremy
Old 03-08-2013, 08:41 PM   #23
The Kid
The Kid's Avatar
What does mlt stand for?
Jeremy
Old 03-08-2013, 09:01 PM   #24
eurob
tile and stone installer
eurob's Avatar
Mick
Leveling
Terminator
Roberto
Knowledge -- something you cannot undo once you learn about it --
Old 03-08-2013, 09:12 PM   #25
Eschbach
Tile Contractor-Virginia
I was ready to pull the trigger on the TLS next week but I may hold off now.Pretty impressive stuff.I have some large format natural stone coming up and would like to try a leveling system.
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Old 03-08-2013, 09:29 PM   #26
jwmezzanotte
jwmezzanotte's Avatar
Interested
Interested more in the price of the "foot thingies" more than the rest of it. I dont mind paying for tools i can reuse.
Paying for more straps is the worst part of the tls. I still use them all the time though
Old 03-08-2013, 09:36 PM   #27
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I don't understand the need for so many different foot plates.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Old 03-08-2013, 09:39 PM   #28
Kilauea
LT
Kilauea's Avatar
Looks very innovative!
I can't wait to get my hands on some!!!
*L.T.*
tandctile-dot-net
2nd generation tile installer
The apprentice rocket scientist was having a hard time programming the launching sequence.His professor watched impaitently and said,"C'mon its not tilesetting!!!"
Kilauea is offline   Reply With Quote
Old 03-08-2013, 09:50 PM   #29
MICK1
The MLT system will be very competitive in pricing, at the end this was designed to be friendly economically to the installers, we got you guys covered first, as we never forgot where we come from. MLT stand for mechanical lippage tuning system, if you look on top of the cap there is a slid where a stainless steel insert can be slide in when the plastic grabbers will wear out after several dozen of uses. Straps and caps are designed to last a very long long time saving you money and still giving a very hi quality tool to the method. Production will be starting in tw two continent first ( Italy for Europe and USA for America and the rest of the world) by next year we hope to have production in four continents, cutting further carbon footprint and make the system widely available. Also we wanted to make a product that was responsible and friendly to the enviroment.
Thank you guys.
Mick.
MICK1 is offline   Reply With Quote
Old 03-08-2013, 09:56 PM   #30
jwmezzanotte
Thanks mick,
Always found the tails of tls straps such a waste. Meaning more environmentaly than cost. Glad to see that adressed
Tile Leveling Systems Plumbline Tile Forum/Advice Board 8 12-21-2011 09:35 AM
fat mud on plaster and leveling systems asutterer Tile Forum/Advice Board 3 11-09-2011 10:38 PM
Self-leveling countertop system for ceramic tile Dale Watnee Professionals' Hangout 34 02-17-2002 10:47 PM
