Old 01-27-2013, 06:25 PM   #1
bill sosebee
sealers
just built 5'x6' steam shower, tile counter tops and tile floor. do these areas need sealers?
bill
bill sosebee is offline   Reply With Quote
Old 01-27-2013, 07:04 PM   #2
The main function of sealer is to buy you some time to clean a spill before it possibly becomes a permanent stain. Depending on the material used, some tile and grout benefits from sealing and some doesn't.
What type of tile did you use on each of these areas? If it's a man-made tile with a glaze on it, is it glossy or matte? And can you tell us what kind of grout was used?
Old 01-27-2013, 07:56 PM   #3
bill sosebee
sorry i don't know anything about tile except its cold on my feet, wife is handling all this. but thanks for the help
bill
Old 01-27-2013, 08:09 PM   #4
doitright
doitright's Avatar
Hi Bill, Welcome!
Sounds like you need to introduce us to your wife.
Sent from my EVO using Tapatalk 2
John Koessler
Old 01-27-2013, 09:18 PM   #5
Maybe we should be recommending he buy some warm slippers?
Old 02-11-2013, 08:58 AM   #6
CitadelBlue
I'll Try Anything
CitadelBlue's Avatar
Not to high jack this thread, but is there a general rule as to how often you should reseal the shower grout?
Ken
CitadelBlue is offline   Reply With Quote
Old 02-11-2013, 09:39 AM   #7
StoneTooling
Vending Machine
StoneTooling's Avatar
Sealed surfaces should repel water. It really depends on how porous your grout is as porous grout will appear to absorb water even if properly sealed.
Generally, if you put water on the grout surface and it beads, it's good to go. If you drop water on it and it soaks up like a sponge and changes the color, it may need to be sealed.
Again though, there are exceptions to the rules.
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
Old 02-11-2013, 04:30 PM   #8
obsia
Depends on what stone it is. If it is granite you should be okay compared to say a limestone, travertine or marble. Although sealing would be best even if it is a granite. I am assuming it is honed finish tile.
Tool guy is right, sealer will just buy you some time to clean up the spill. If you want something makes absorption nill and would like to maintain the original look then I would recommend Permeators (we manufacture them).
Grishma
Obsia - Manufacturer of Permeators.
We are an R&D based company that focuses on eliminating the causes of staining, weathering and issues we run into with stone and concrete surfaces.
Instead of making the stone only resistant by just filling in the pores - we eliminate the porosity, decrease negative effects of mineral impurities and structural deformities.
We don't believe in masking the problems, we believe in addressing the source and causes of such problems.
www.obsia.com
obsia is offline   Reply With Quote
sealers shelley belly Cleaning, Restoration and Sealing 10 10-30-2010 10:43 AM
Which Sealers to use jillio27 Cleaning, Restoration and Sealing 0 07-12-2010 08:37 PM
Sealers Katie Tile Forum/Advice Board 2 10-12-2004 05:33 PM
sealers jscott9330 Tile Forum/Advice Board 2 12-22-2003 08:22 PM
Help on Sealers!! mlee Tile Forum/Advice Board 12 09-22-2003 08:25 PM
