Old 01-22-2013, 08:18 AM   #1
Hammy
Hammy's Avatar
To fill or not to fill ( waffles )
How many of you guys prefill or not prefill your DITRA waffles?
Trying to get a count either way.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Old 01-22-2013, 08:38 AM   #2
pgc555
Hammy,
If I am NOT setting the tile that day ( do to time ) I will use up my modified thin set and fill the waffles - allow to dry. Key-in the next day and set as normal with non-modified.
I did a test with Ditra and other substrates about back-buttering tile. The thing that surprised me when I pulled up the tiles from the Ditra is that ALL the thin set came out of the waffles with either tile. Back-buttered or not.
I doubt if by filling the waffles first or just doing it when you set would change this.
http://www.youtube.com/watch?v=bF2SgLBF6qI
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Old 01-22-2013, 08:40 AM   #3
eblumer
EJ Flooring
I don't prefill. I set my tile with a cheap laser and I can see it just fine on the Ditra. At the end of the day I will fill waffles to keep from wasting any thinset (whatever I have left that wont set a tile).
Eric
www.ejflooring.com
eblumer is offline   Reply With Quote
Old 01-22-2013, 08:48 AM   #4
Grovertile
Not a cute furry blue guy
Almost only prefill
Dane Grover, all grown up and still playing in the mud...
www.grovertile.com
Grovertile is offline   Reply With Quote
Old 01-22-2013, 08:54 AM   #5
cwilde72
cwilde72's Avatar
Depends on my mood that day. I'd say I'm about 50/50
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Old 01-22-2013, 10:09 AM   #6
Schluterman
Western NY Tile Contractor
Never, dont see a reason for it. Most of the time i use straightedges to set, and always makes a additional mess to vaccuum up, Thats one of the benefits of ditra, a nice clean surface. I will though, throw leftover thinset in a closet at the end of the day.
John Mullett Tile Co.
Lockport NY
Schluterman is offline   Reply With Quote
Old 01-22-2013, 10:20 AM   #7
Obie1
Tile Contractor
Obie1's Avatar
If I have a chance to give the ditra a day to set up and pre fill the waffles I will.
-Obie
ELITE TILE WORKS
(805)845-8787
Southern California ceramic and stone tile contractor serving Santa Barbara and Ventura counties
http://www.elitetileworks.net/
Obie1 is offline   Reply With Quote
Old 01-22-2013, 12:35 PM   #8
tileman2000
New England Tile Man
tileman2000's Avatar
Michael
Old 01-22-2013, 02:11 PM   #9
Donnie D.
I love Mud!
i had pre filled the waffles on a recent job..i let it sit over nigh for 14 hours..then started to tile..it seemed very dry but i still dont now about prefilling the waffles unless u give the 48 hours to full cure and then set tile..i keep debating on this
Don
Donnie D.'s Tile&Remodeling LLC
-bathroom remodeling,tile,interior doors,molding,drywall..
from remodeling to repairs
out of central jersey
https://www.facebook.com/DonnieDsRemodeling
Donnie D. is offline   Reply With Quote
Old 01-22-2013, 02:25 PM   #10
Un filled waffles do not hold up well to wheelchairs, fridges, or carts loaded with tile.
Just thought I'd throw that out there.
Old 01-22-2013, 03:47 PM   #11
Phil,
Not to thread jack but I demoed 200 ft of tile and ditra yesterday when the tile came off the ditra the thinset pulled from the waffles with it and crumbed out of the waffles, I expected it to lock into the waffles better then it did, the ditra tearout was simple too, easier then I thought, anyways I do not prefill.
Old 01-22-2013, 04:04 PM   #12
MudMaker
MudMaker's Avatar
Prefill if the timing is right.. and I use Versabond to set the tile... I know...
mm (aka "Paco")
Old 01-22-2013, 04:26 PM   #13
alex.h
prefill kina guy
Alexandre G.V. Hamel. Compagnon région de Montréal
alex.h is offline   Reply With Quote
Old 01-22-2013, 04:54 PM   #14
if I'm doing a small bathroom or something under 150-150 sq.ft. I wont fill.
because I can set the Ditra and set the tile in 1 day.
if I'm doing a big job (200 + sq.ft.) I prefer to pre fill. I can float the waffle in way faster then trying to push thinset around while setting.
snapping lines is so much better and less thinset i'm moving when setting the tile.
Old 01-22-2013, 05:57 PM   #15
A Ditra installation only has to achieve 50 psi shear bond. Just about any thin-set will do that. It doesn't matter that it comes up easy.
To fill or not to fill teamjenny Tile Forum/Advice Board 4 06-27-2010 10:40 PM
Fill in D&BT Tile Forum/Advice Board 16 11-13-2006 11:19 AM
Fill this out before asking questions flatfloor Computer Training 0 05-02-2006 01:36 PM
What can I fill this gap with? jflenniken Tile Forum/Advice Board 14 01-02-2006 11:26 PM
what to fill the gap with??? mitcheal Tile Forum/Advice Board 2 01-09-2002 06:11 PM
