Old 10-08-2012, 06:38 AM   #1
awhiteman28
6 x 24 Wood Look Tile
I am installing the same tile, I had a question. I used a 1/4 x 1/4 notch trowel but used just a slight angle when troweling out thin set. I pulled up several pieces to check coverage and it was 80% plus. I know on larger tile you should try and use a 1/4x3/8 trowel but I went with the tiles width of six inches to determine trowel size. Any comments would be very helpful.
aaron
awhiteman28 is offline   Reply With Quote
Old 10-08-2012, 06:52 AM   #2
prostuff1
From what I have read and been told a 1/2 x 1/2 square notch is what is normally used for these floor tiles. the 6 inch wide does not matter so much and the tile is still considered large format.
When I do my upstairs and first floor I will be putting down a lot of this wood look tile and will be going with the above mentioned size of trowel.
Kyle
prostuff1 is offline   Reply With Quote
Old 10-08-2012, 08:20 AM   #3
Welcome, Aaron.
Your trowel type and size should be whatever gives you the necessary coverage on the back of each tile while providing a minimum of 3/32nds" mortar thickness after the tiles are set.
If your substrate is suitably flat and your tiles are suitably flat, there is no need for an excessively large notch size.
Keep in mind that 80 percent coverage is the absolute minimum and you really want to get as close to 100 percent as possible. And you always want good coverage on all edges and corners.
Old 10-08-2012, 10:54 AM   #4
karlkatzke
karlkatzke's Avatar
Aaron, are you back burning the tiles?
Karl - Homeowner, DIY-er, someday slumlord
"Itís not enough to be aware of the domain youíre working in, you need to understand it. Noticing things and being curious about how they work is the single most common trait I see in creative people. Once you can break the components down, you can put them back together into something brand new." - Seth Godin
karlkatzke is offline   Reply With Quote
Anyone used wood look tile? amandalei9 Tile Forum/Advice Board 11 02-27-2010 07:51 PM
Wood and Tile, how? HomeDepotAssociate Tile Forum/Advice Board 21 02-26-2010 10:36 AM
Tile on Wood Gary K Professionals' Hangout 9 03-15-2008 07:15 PM
Wood under Tile again carolaallen Tile Forum/Advice Board 14 02-13-2004 07:03 AM
Tile on wood on wood? MartinHome Tile Forum/Advice Board 3 12-11-2003 08:44 AM
