Old 07-25-2012, 04:50 PM   #1
Wayne555211
Wooden shower pan
Is it possible to build a shower pan from wood, then use dura rock or hardie board with Kerdi membrane on top, prior to tiling?
Wayne
Wayne555211 is offline   Reply With Quote
Old 07-25-2012, 05:29 PM   #2
Welcome, Wayne.
Not at all sure what you have in mind there. CBU is an appropriate substrate for Kerdi, although the manufacturer prefers gypsum board. If you covered your shower pan with such material, properly installed (would hafta be over plywood or OSB), you could apply Kerdi to it.
But I'm afraid I don't understand how you intend to construct a properly sloped shower pan of such materials and have them end at anything but maybe a linear drain.
Tell us more about this plan.
Old 07-25-2012, 05:32 PM   #3
dhagin
Welcome Wayne.
Yes build the subfloor out of wood as explained in Kerdi's installation instructions, then cover it with deck mud or their foam pan.
dana
Old 07-25-2012, 05:41 PM   #4
Wayne555211
I was thinking of making a wooden PAN (the subfloor is wood anyway - normally the mortor is protected from getting wet since it would destroy the subfloor if it did). I would use the Dutra or the Kerdi fleece over cement board for the water proof part.... Did you guys read my first post?
Wayne
Old 07-25-2012, 05:45 PM   #5
Wayne555211
Wooden pan could be made very solid and exactly sloped cutting 2x material on a table saw.
Wayne
Old 07-25-2012, 05:49 PM   #6
dhagin
Ya know Wayne, anythings possible IMO. Ya wanna build some kinda wood sloped thing and cover it with backer board & Kerdi in your own house, that's your choice. How ya planning on getting the drain to work?
Will this sloped wood thing work & last? Highly unlikely. Kinda curious why you'd wanna go and do something like that...
Much easier to follow Kerdi's installation instructions and set yourself up for success.
dana
Old 07-25-2012, 05:59 PM   #7
Wayne555211
I figure that the wood pan is a lot cheaper and easier to construct. A custom plastic pan that accepts tile seems to cost about $500. I used the shower drain that tightens between the plastic of a fiberglass formed shower before. I would put the kerdie, and or a membrane between that. The cement board is pretty much like a mud base. Just that the wood below starts a 1/2 in away rather than from 1 1/2 to 3 inches away. None of that (including a normal mud base) should get wet anyway...
Just an idea.
Wayne
Old 07-25-2012, 06:05 PM   #8
dhagin
1- With Kerdi, it's best to use a Kerdi Drain.
2- Materials for a mud shower floor cost about $25 depending on it's size. It's just sand & cement.
Read thru the Kerdi Shower Handbook and take a look at the mud base details. Also check out the Liberry for how to build your own mud base.
http://www.johnbridge.com/vbulletin/...ead.php?t=5434
http://www.johnbridge.com/vbulletin/...ad.php?t=36312
We've walked many many first time DIYers though the process successfully. There's also a thread showing how to build a test shower floor to practice shaping a mud floor.
http://www.johnbridge.com/vbulletin/...ad.php?t=83577
dana
Old 07-25-2012, 06:07 PM   #9
Yup. You read my first response?
Wayne, there is nothing you can build with wood or any similar material that is gonna be less expensive or easier than making a properly sloped shower floor from deck mud. Nothing at all.
Have you read the Installation Handbook for the Kerdi shower system on the Schluter website? Shows both the proprietary foam tray and deck mud methods of constructing the shower floor.
I've done a bit of woodwork and I've built a few mud shower pans and I assure you you really wanna do the mud floor.
Old 07-25-2012, 06:16 PM   #10
Wayne555211
Mud is cheap. But, I have carried this stuff up many floors in an elevator before and I am not looking forward to it again. This time I will be on the 3rd floor of a nice condo building that was stick built (OSB on the floor). Mud is a possibility. But, to save time, etc. other people have paid $500 for that pre-formed plastic pan that gets tile on top, so I do think this idea is a relevant possibility.
Wayne
Old 07-25-2012, 06:17 PM   #11
Wayne555211
Sorry, I think your first response was changed while I was in the process of responding ...
Wayne
Old 07-25-2012, 06:18 PM   #12
dhagin
This your place Wayne?
dana
Old 07-25-2012, 06:51 PM   #13
Wayne555211
My rental. Gypsum shower pan, that's funny....
Wayne
Old 07-25-2012, 06:58 PM   #14
dhagin
3rd floor condo, with other owner(s) below? I just did this exact same thing with a mud + Kerdi shower.
Pay for a helper to carry the mud if you don't wanna carry it, I did. You'll still be ahead on $$. The consequences of a leak are not minor IMO. Do it right and sleep well at night with no worries.
dana
Old 07-25-2012, 07:35 PM   #15
Wayne555211
OK, so we have proven that mud and Kerdi is viable ..... Back to the question, how about wood and Kerdi. After this shower is done, I was thinking about making a wooden hot tub or swim pool ....
Wayne
Rotted tiled window sill and wooden window in shower Sean12 Tile Forum/Advice Board 5 06-27-2011 05:08 PM
Wooden Frame in Shower area.. How TILE & SEAL... HELP overkillxx Tile Forum/Advice Board 4 09-30-2008 08:01 AM
Shower seat made of wooden bench, is that a problem? scorleo Tile Forum/Advice Board 5 04-03-2006 04:11 PM
wooden bench in Kerdi shower... nrcurcio Tile Forum/Advice Board 7 04-03-2006 10:04 AM
Wooden Doorstrips Dan the Man Tile Forum/Advice Board 5 03-09-2004 06:13 AM
