Old 06-22-2012, 05:07 AM   #1
tilemanct
Tile & Stone
Deflection and Mud Work
Got into a discussion at the local tile distributor the other day with an installer who does a lot of mud floor work. I told him how I often have to decline mudding floors due to added mud height, weight, and deflection. He said that you don’t have to worry about deflection with mud work, as the mud job takes it out. He also mudds to a thickness of 1” to 1 1/8” even on the 500 sq/ft + jobs. I always thought you needed to be at least 1 ˝” minimum on anything over 100 sq/ft. I always made sure any added weight of a mud job was accounted for in the floor structure design. He said you don’t have to worry about that, joists can take it. What am I missing? Am I too cautious? I can’t tell you how many jobs I have run through the Deflecto lately that give me thumbs down to ceramic tile. I couldn’t imagine putting 1 ˝” mud on top.
CTEF Certified Installer
Old 06-22-2012, 08:57 AM   #2
Sounds like we're mixing some methods here, Dave. Are you're talking about this use over wood framed subfloors?
Old 06-22-2012, 10:22 AM   #3
The Guy who taught me would mud over anything. I remember mudding over some bouncy floors these were over 1000 sq ft too. I am like you I check everything your better off in the long run. If I can't mud I plywood and ditra.
Old 06-26-2012, 04:50 AM   #4
tilemanct
Tile & Stone
Yes CX, Wood Frame Subfloors.
Old 06-26-2012, 09:18 AM   #5
Not sure what your installer friend is relying upon for his information, but as far as I know there is still a requirement for a joist structure and subfloor that meet L/360 deflection requirements to use the method I think you are referring to (F145 in TCNA Handbook). Maximum joist spacing is 16" on center and minimum subflooring is nominal 3/4" T&G plywood.
I'm told that method once had a limitation of no more than 100 square feet, but that's no longer in the published method.
You can get a Light Commercial rating if done correctly.
Old 06-26-2012, 08:39 PM   #6
Yeah, I've mudded many bath floors as thin as 1/2 to 3/4 inch without issues. They were all under 100 sq ft, most were 50 ft or less.
Old 06-27-2012, 04:55 AM   #7
tilemanct
Tile & Stone
Well CX,
He believes that mud takes out deflection no matter what the situation is. That was where I began to question his reasoning.
Old 06-27-2012, 06:29 AM   #8
e3
I would think that the deflection may be OK(depending on what it is) but the joist may not take the weight.(dead and live)
Eric
Mapei USA
Old 06-30-2012, 08:32 AM   #9
vrusso123
N. E. Ohio tile-setter
many a fella here in ohio think paper and lathe fix any structural/ subflooring problems and convince the homeowner of this during their sell. i have 2 copies of the T.C.N.A. i give to these homeowners to give to their tile guy as a courtesy. i always get them back when i do the job.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Old 07-01-2012, 06:50 AM   #10
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
I'm thinking along the same lines as Eric. So long as the joisting can handle the weight, within reason, you should be okay, especially in a situation where the drypack isn't bonded to the subfloor, and requires wire reinforcement. It SHOULD add structural strength (and stability, with respect to deflection) to the floor, in my way of thinking. I don't know if a 1" bed would cut it, though.
Bill
Old 07-01-2012, 08:29 AM   #11
coping skills
CSC
coping skills's Avatar
All I know is I once tore out a mud bed which was 8" thick going down between chamferred 2x8 joists.
I can't think of any deflection having an effect on a mud bed like that. That mud bed was basically a structure independent of the house. A sovereign mud bed.
-Luke
Quality Crapsmanship.
In love with liquids.
coping skills is offline   Reply With Quote
Old 07-01-2012, 11:02 AM   #12
Deflection actually occurs in two areas: in the subflooring between the joists and along the length of the joists. I agree that an adequate mud bed will stiffen the floor between the joists. Whether the overall floor can take the load is another matter. Short answer: yes, a reinforced mud bed can stiffen a floor.
But an additional sheet of plywood will do the same thing.
mud work larrylou Professionals' Hangout 117 10-30-2011 02:33 PM
mud room deflection the juggler Tile Forum/Advice Board 9 01-06-2011 09:04 AM
Mud Work Charles P Professionals' Hangout 2 01-11-2008 07:33 PM
Mud Bed for deflection GabeS Professionals' Hangout 6 01-06-2007 08:28 PM
How does Deflection work? donbender Tile Forum/Advice Board 3 07-14-2006 09:17 AM
