Old 04-08-2012, 12:16 PM   #1
Tub Refinisher
Black marks on tile regrout job
Hey guys, I'm new here. I posted on Terry Love's forum and my thread got hijacked by 2 guys fighting about some stupid stuff. One of them suggested I post over here. I'm a Perma-Glaze franchise owner/operator, so re-grouting isn't my primary line of work.
I did a re-grouting job for a friend, and while removing the grout, the oscillating tool slipped in a few places and while it didn't cut the tile, it left a few black marks on the white ceramic tile that I cant get off. I've tried everything I had: grout cleaners, tile cleaners, mild acid cleaner, barkeepers friend (which normally take black marks off of bathtubs when nothing else works), acetone, lacquer thinner, you name it. It's actually a very slight scratch that is black. Any ideas from you pros on what might take it off? Bleach maybe? Someone suggested toothpaste, but considering what I've already tried, it doesn't seem like it would work. I have to go back Wednesday to resurface that bathtub, and I told him I'd find something to use by then. HELP!!!
Barry
Barry
Tub Refinisher is offline   Reply With Quote
Old 04-08-2012, 12:23 PM   #2
Welcome, Barry.
You're in the right place, threads never get hijacked here.
Hang on, one of our cleaning gurus might have an answer for you, but it'd certainly help if you posted a photo of your marks and tell them with exactly what material the marks were made.
Y'ALL NEW VISITORS READ THIS HERE! ...... HUNT ELK & IBEX IN NEW MEXICO
test note
Old 04-08-2012, 12:29 PM   #3
Tub Refinisher
Thanks, CX. I don't have photos handy, but the marks were made by the cutting blade on the oscillating tool by slipping out of the grout line and lightly abrading the surface of the tile. The marks would hardly be noticeable except for the fact that they are black, on white ceramic tile.
Barry
Barry
Old 04-08-2012, 12:31 PM   #4
So, this was a steel tool, a diamond tool, a carbide tool, an emerald encrusted ivory tool, what? More hints.
test note
Old 04-08-2012, 02:06 PM   #5
Tub Refinisher
Diamond tool
Barry
Old 04-08-2012, 03:17 PM   #6
Davestone
Florida Tile & Stone Man
I've had the same problem before and used many things as you have and never found the perfect cleaner,maybe others have.But i did get it mostly off using some wet sanded grout,toothpaste might just work.
Do what you can,with what you have,where you are..Teddy Roosevelt
http://Davestonestile.com
Old 04-11-2012, 03:48 PM   #7
Miracle Sealants Tech
Miracle Sealants Tech's Avatar
Hi Barry-
You may want to try our Porcelain and Ceramic Tile Cleaner, which is an abrasive cleanser we manufacture. It is sort of like a jewelers rouge for tile.
I have successfully taken Marks-A-Lot marker off of tile before. Use it with a really good scrub pad, like the back side (green) of a dish sponge.
The other option that I have used in the past to take the grid markings from the back of tile off of the front of the tile (developed from rubbing together during shipping) is to use a very light grit sand paper. Start with a fine grit (to make sure you do not scratch the tile) and progress to a more aggressive grit (that the tile will allow without affecting the finish of the tile) to see if it will take off those black marks.
If there happens to be a left over tile from this job when it was completed, you can always use a spare just to see how aggressive you can go with the sand paper.
Good Luck
Robb
"Serving the Tile, Stone and Masonry Industries for 25 Years"
www.miraclesealants.com
Miracle Sealants Tech is offline   Reply With Quote
Old 04-25-2012, 10:13 AM   #8
Windwood
Windwood's Avatar
You might try some automotive rubbing compound or polishing compound. Rubbing compound being the more abrasive. I have cleaned Le Crueset porcelain coated cookware with both and they worked very well. I doubt you could do any damage to the tile with them, but as always, do a test first.
Windwood is offline   Reply With Quote
Old 05-12-2012, 06:13 PM   #9
Hank B.
It's likely the steel from the blade. In the same way a pencil marks a piece of paper, dragging steel over tile the steel wears off onto the tile. gently rubbing it with a pumice stone is the only way I've gotten it off. If it's a really glossy tile, then it might dull the surface though, but that's the only way I know to get it off.
Hank
Hank B. is online now   Reply With Quote
large job on a budget and black cutback.. big jilm Tile Forum/Advice Board 5 03-27-2012 10:35 PM
Black marks Big Randy Cleaning, Restoration and Sealing 9 06-03-2011 01:09 PM
Porcelain regrout job kelso Professionals' Hangout 6 07-12-2005 09:59 AM
My first tile job is just about complete - black granite and schluter (pics) kjdiver Tile Forum/Advice Board 7 05-16-2005 04:53 PM
Installed black granite tile... need black caulk or flexible filler alkon Tile Forum/Advice Board 6 04-03-2005 09:24 PM
