Oh no
You are going to have to use Methylene Chloride to strip it.
Dun Edwards carried a product called “Strip-X” that was the best retail stripper available. They private labeled that product for years, but switched manufacturers a month ago, or so. They claim it’s the same formula, so you might give DE a call. They’re all over Cali…it’s a paint store.
If you strike out, True Value Hardware carries “Sunnyside Glue & Adhesive Remover.” This is your second best option.
Coverage is approximately 50 sq.ft./gal of stripper/application.
Make sure the surface is DRY before applying.
Work in small areas. Say 5’x5’
Pour stripper into a puddle.
Spread with a grout sponge. Cake it on thick (1/4” or more) Wear big rubber gloves.
Let dwell for at least 10 minutes, but no more than 20 minutes.
Splash some water on the stripper.
Scrub with a stiff nylon brush.
Splash a little more water on it.
Scrub with a green scrub pad.
Wet-vac the whole mess up.
Repeat (once the surface is dry)
Good fun, eh?
