Old 05-03-2012, 08:06 AM   #1
mjarema414
Questions regarding tile tub wall corners
Hi, I recently had by bathroom remodeled. THe contractor did a great job overall but he grouted the corners where walls meet and where the tile meets the tub. After 2 months it's starting to form hairline cracks. It's an older house built around 1920. After reading some posts, it's seems these corner walls and tub/tile base should have been caulked. I initially bought the siliconized caulk to match my Polyblend unsanded grout, scraped the corner walls out of grout and caulked. After further reading, I should have used 100% silicone. My next move was placing an order with Colorrite INC for the 100% silicone that matches my grout.
On to my Questions, the first caulk that I used didn't fill in the entire space of the corner walls. I cut the tip smaller as I didn't want a thick bead. Since it's fairly new (one week old), Can I go right over this with a bead of 100% silicone? Also, a soap dish and 2 shelves were installed and grout surrounds the space between tile and dish. There is still a small gap. Can I just go over the grout with the silicone since there is a gap and the color matches the grout?
Thanks for your help.
Matty J
mjarema414 is offline   Reply With Quote
Old 05-03-2012, 09:49 AM   #2
mjarema414
Thanks Bob. THe grout around the soap dish/shelves is not cracking. As far as the caulk goes, I just caulked last week so it's relatively new. I understand it's not ideal to caulk over caulk but there is still a void/gap for the silicone to fill. I'm assuming I should just dig it out and start over.
Matty J
Install tub on exterior wall, vapor barrier questions Big Tom Tile Forum/Advice Board 10 05-06-2011 06:18 AM
Trim for tile wall corners rambo1224 Tile Forum/Advice Board 15 05-05-2010 01:18 PM
Tub/wall joint caulk questions (now that it's too late...) ctate Tile Forum/Advice Board 10 10-27-2008 05:33 AM
few questions on wall tiles around tub & walls nicktakos Tile Forum/Advice Board 1 10-29-2004 06:24 PM
Grout or caulk tub wall corners? wildwire Tile Forum/Advice Board 2 10-28-2004 06:45 PM
