Old 11-28-2017, 11:07 AM   #16
Probably, but I'd still try a wet sponge and maybe a white scrubbie to see if I could get that fleece a little cleaner.
Old 11-28-2017, 12:28 PM   #17
JillD
Okay will do. Thanks again!
Jill
JillD is offline   Reply With Quote
Old 11-28-2017, 12:58 PM   #18
MisterJJ
I did add a little more water as I broke up some clumps at the end
Did you add water to thinset that had already been mixed and slaked? I think that's a definite no-no. May be a good cause of the easy removal.
Joe
MisterJJ is offline   Reply With Quote
Old 11-29-2017, 08:56 PM   #19
Atomic21
I second that you should not be adding water to the thinset. Weakens it significantly.
I've found that getting consistent product from versa bond requires a quality postal scale (to weigh the batch), a decent measuring container (usually from the paint section of the big box store, and a mixer attachment on my drill. Store the dry mix in a dry place as it'll suck humidity from the air.... from my days of working in a concrete lab, humidity contamination of bags of cement was murder on the results. Worst case, store the bag in a sealed home depot bucket.
If you pull the ratio, its like 0.11 qts (3.5oz) per pound of dry mix.
John
Atomic21 is offline   Reply With Quote
Shower Dam/curb. Kerdi board or kerdi membrane over sheet rock? Shady at Best Tile Forum/Advice Board 11 01-20-2016 09:44 AM
shower membrane over curb pronouncedeyen Tile Forum/Advice Board 13 10-31-2015 12:21 PM
Kerdi shower - air pockets problem vfreeman Tile Forum/Advice Board 7 12-12-2008 01:41 PM
kerdi floor - lumpy and air pockets SeanMD Tile Forum/Advice Board 2 06-17-2008 11:46 PM
