Old 10-29-2015, 09:46 AM   #1
pronouncedeyen
pronouncedeyen's Avatar
shower membrane over curb
I'm in the process of building a frameless glass shower with 2 glass walls. That means that I will have shower curbs on 2 sides of the shower. What do I do at the point where they meet? I've seen videos and guides that show you how to use those pre-folded pieces to cover up the corner where your curb meets the frame (or wall) but how do I cover things up at the corner of 2 curbs? My mathematical brain can't seem to figure out how to fold it to make it work!
Ian
pronouncedeyen is offline   Reply With Quote
Old 10-29-2015, 10:57 AM   #2
Jaz
Michigan Tile Pro
Jaz's Avatar
Hi Ian,
Several ways to do that. You can fold, double cut then weld together.
But wait a minute, What will you be installing over the top of the membrane as the tile substrate?
Jaz
Troy, Michigan
Custom TileSetter (retired) - Method & Product suitability consulting
DIRECT Containers MARBLE from ITALY - GREECE; PERLATO di SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - ARETI WHITE - CALACATTA - others - Slabs - Tiles - Custom marmo.sicilia@yahoo.com
Old 10-29-2015, 11:40 AM   #3
If you buy preformed corners, you'll need both inside and outside corners - a pair of each. Folding could work, but would result in more buildup. Assuming you're talking about Kerdi, the corners are thinner, and have less buildup than the fabric sheets.
Old 10-29-2015, 01:33 PM   #4
Jaz
Michigan Tile Pro
Jaz's Avatar
I don't get the impression Ian is doing a Kerdi shower, sounds like a traditional membrane. We'll find out soon.
Jaz
Troy, Michigan
Old 10-29-2015, 01:42 PM   #5
Buildup with a traditional liner can be compensated when installing the mortar and lath over the top. The cement used to bond the pieces together should allow you to get good coverage without any leaks. You'll have to cut the liner and patch a piece on top of it to cover the cuts. Some curb dam corners should help.
Old 10-29-2015, 02:24 PM   #6
Jaz
Michigan Tile Pro
Jaz's Avatar
Absolutely, just fold it if going that way. But many people try to install CBU on the curb area which messes everything up.
Jaz
Troy, Michigan
Old 10-30-2015, 10:22 AM   #7
pronouncedeyen
Thanks all for the quick responses! I'm planning to wrap metal mesh around the curb as described here: http://floorelf.com/creating-a-thres...or-your-shower
Is there an easier way? I can't think of a way to attach backer board to the membrane without puncturing it.
Ian
Old 10-30-2015, 12:41 PM   #8
You don't want to attach backer board to the curb in any way. It's actually a very common mistake we see hereabouts, one that leads to failure of the shower.
Old 10-30-2015, 05:09 PM   #9
Jim Cordes
One trick is to leave gaps in the wood curbs and corners so you can tuck the liner into them to try to keep the thickness down...that and chisel or cut the wood to allow for the liner..you will see its not an exact science..you just do what you can. But i would try to avoid cutting the liner if at all possible.
Jim
Jim Cordes is offline   Reply With Quote
Old 10-30-2015, 05:21 PM   #10
Jaz
Michigan Tile Pro
Jaz's Avatar
Ian,
You said you're gonna wrap lath up and over the curb, so, there will be no punctures. You shape the lath and fasten only on the outside. There is no need to chisel, tuck into any gap etc. when you build the inside, top and outside of the curb with mud.
Alternatively I woulda done a shower with surface waterproofing instead. But if you're committed to the traditional method, continue per above.
Jaz
Troy, Michigan
Old 10-30-2015, 11:31 PM   #11
pronouncedeyen
By surface waterproofing do you mean Kerdi? I was thinking about it but it's a big shower and Kerdi would've added almost $1000 to the cost. And also I'm cheap.
Ian
Old 10-31-2015, 12:04 AM   #12
Ian, Kerdi is but one product that meets the requirements of ANSI A118.10 as a waterproofing membrane suitable for building your shower. I would always recommend a sheet-type membrane for that purpose. Kerdi is one such. You might also look into the USG Durock Shower membrane. There are others.
Your shower would need to be exceptionally large to require a thousand dollars worth of waterproofing material. You're probably looking at well under half that. I would not recommend you buy the kit, but rather only the components you need, which is essentially a drain and the necessary membrane.
But even at $1000, a thirty-year shower is gonna cost you less than $35 a year for the waterproofing. Sounds pretty reasonable to me.
Old 10-31-2015, 10:08 AM   #13
Jaz
Michigan Tile Pro
Jaz's Avatar
Ian,
I'm not sure how you came up with 1k more for a Kerdi shower.
I used to figure about $300 for Kerdi Drain and all fabric to do a typical shower, plus and extra day labor compared to skipping the surface waterproofing steps. So maybe $700 +-. But now the client doesn't need a plumber to install the pan and drain. Deduct his charges and we're close to zero added cost plus the results are much better. No comparison.
Jaz
Troy, Michigan
Old 10-31-2015, 12:21 PM   #14
Maybe adding in a tray and all the corner pieces, if there are any. Still, $1k would probably be a very high estimate.
Like CX, I've been using the Durock shower membrane lately. I get it through Amazon for about $1.30 a square foot, no tax, no shipping. I still use the Kerdi drain, and while it is expensive, it's a reasonable cost compared to the alternative clamping drain/PVC liner system.
Shower Dam/curb. Kerdi board or kerdi membrane over sheet rock? Shady at Best Tile Forum/Advice Board 11 01-20-2016 09:44 AM
Liquid Membrane/ Sheet Thinset Membrane Drain Connection Philosophy jasoncpe Professionals' Hangout 24 10-25-2015 10:44 PM
Tile directly to membrane on curb? daveaz Tile Forum/Advice Board 16 01-30-2015 07:28 PM
Tiling a varying-height shower curb; Penny tile OK on top of curb? smcquaid Tile Forum/Advice Board 6 01-07-2012 09:02 PM
Tools for Curb Mudding that won't rip membrane? Twortle Tile Forum/Advice Board 17 11-23-2004 07:09 AM
