Old 08-27-2014, 01:59 PM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Shower Dam/curb. Kerdi board or kerdi membrane over sheet rock?
I am helping a friend with a 3 foot shower dam tonight. It's going to be 3 to 4.5 inches tall, it's up to him on the height. The dam will have 2-3 2x4's stacked. We are using kerdi membrane and a kerdi drain so the mortar bed will be on top of sub floor. Our options are either boxing out the dam with 1/2 inch kerdi board and finishing the edges with kerdi fix and membrane or to cover the wood with sheet rock and then cover it in membrane. Covering it with sheet rock/membrane will be a tad more labor but could be covered with a single piece of membrane plus the edges being totally covered. Using kerdi board over the 2x4's will have seams on top that will need to be sealed and covered with kerdi ban in addition to the seams at the walls/dam.
I suppose I could run some lath over the dam and float it then cover it but that seems like a lot of work.
With the possible pros and cons which way would you folks do it?
Travis
It's just a clever handle.
Old 08-27-2014, 04:40 PM   #2
RichVT
Vermont Remodeling Contractor
You could skip the wood and make the whole curb out of Kerdi Board if you want. Either way, extend the pan Kerdi over the curb and you'll have fewer seams and less build up.
Rich
RichVT is online now   Reply With Quote
Old 08-27-2014, 05:14 PM   #3
Premier Designs
Wink
I wood never, use wood in a shower .. ; )
Or sheetrock for that matter on the curb, Kerdi board, bricks, solid concrete, those are my options .. water proof as needed ..
www.premierdesigns4u.com
Premier Designs is offline   Reply With Quote
Old 08-27-2014, 05:16 PM   #4
For Kerdi showers I use wood for the curb foundation and cover it with drywall and Kerdi the same as the walls.
Old 08-27-2014, 05:43 PM   #5
Stacked wood on a subfloor works, but isn't a great idea on a slab, so there, bricks, pavers, etc. are better. Saying no wood in a shower is a little harsh...most homes are built with wooden studs, and they're no more in a shower than that of the curb if it is waterproofed properly. Since a slab could let moisture in from below, something more water resistant like bricks or pavers is a better idea.
If you have enough KerdiBoard left, you can stack it up and use it as your curb. Or, use it to cover the framework made from 2x4's, or use the membrane to cover a suitable panel (cbu, drywall, etc.). Use thinset to bond the panels together and to the floor and walls of the curb if you go that route.
Old 08-27-2014, 08:10 PM   #6
2x4's with sheetrock and Kerdi for situations like yours, concrete or bricks if it's over a slab.
Old 08-28-2014, 02:24 PM   #7
Shady at Best
Tyrone shoelaces
Okay. Kerdi membrane over sheet rock it is.
I am actually using the trugard shower kit for this one. It's a friend shower so I let him make the call on the product. So far trugard seems pretty good as compared to kerdi. Although the drain flange does not have a felt rim. Trugard says to seal membrane using their polyurethane caulk. Here is the drain
Travis
Old 08-28-2014, 09:16 PM   #8
While Schluter allows you to use thinset to seal around the drain. I still use Kerdi fix /Sikaflex to seal that joint. So I don't need no steenkin' fleece on my kerdi drains. But it is impressive when you can keep that fleece white and pretty looking for the customers.
Old 08-28-2014, 11:11 PM   #9
Shady at Best
Tyrone shoelaces
I to prefer to use kerdi fix at the drain instead of mortar. I have a lot more faith in the polyurethane making that seal rather than using mortar
Travis
Old 08-29-2014, 10:16 AM   #10
Premier Designs
Having wood on a vertical surface is a little different than introducing a feature into your shower that has the potential for leaks, on a surface that is stressed, and will hold water more readily than a wall, no wood curbs thank you, I'll stick with a solid curb ...
Old 09-01-2014, 11:26 PM   #11
Shady at Best
Tyrone shoelaces
Hey Paul. Which sikaflex do you use? The truseal that came with the trugard kit sucks compared to kerdifix. I would love to find something good that cost less than the 15$ a tube for kerdifix. The kerdifix and wedi sealant seem to be close to the same. They both skin over within 20 mins and dont let go once dry. I stuck two wood shims together with the truseal and pulled them apart the following day. The shims break when done with kerdifix.
Got these pics today from Steve. He hoped to finish the trugard tomorrow and then a water test thurs/friday.
Travis
Old 01-20-2016, 09:44 AM   #12
gunguy05
Just wondering how this turned out and if you had any more install pics? I'm considering the trugard stuff as well.
Thanks,.
gunguy05 is offline   Reply With Quote
Kerdi membrane and cement board chivas Tile Forum/Advice Board 20 08-10-2010 09:12 AM
Sheet Rock with Cement Board? Loren Tile Forum/Advice Board 85 04-29-2010 01:45 PM
Kerdi and regular sheet rock LoydDobbler Tile Forum/Advice Board 5 03-31-2009 03:29 PM
A shower curb with cement board and Kerdi trihai Tile Forum/Advice Board 4 04-30-2007 01:41 PM
Kerdi on Sheet rock Grunt Professionals' Hangout 4 01-19-2005 06:29 AM
