Old 01-13-2018, 03:57 PM   #1
bradley paul
correct mud for curb
I read the mud mix for shower base should be 5 to 1, sand/portland cement mix.
The curb however should have lime added to the mix if I understand correctly. I see a product at lowes that is a type s cement (mortar) mix that is 9 to 2 to 1. sand/portland/lime.
Is this appropriate for the curb?
Or type N cement?
I also saw a quikcrete stucco mix that lowes sells, but my local store does not carry it.
thanks
Brad
brad
bradley paul is offline   Reply With Quote
Old 01-13-2018, 04:26 PM   #2
Lazarus
Lazarus's Avatar
You can either add some lime, or what I do is just use brick morter (mason mix) for my curbs as well as filling the void under Kerdi drains....but, that's just me.
Laz...
“Everything in excess! To enjoy the flavor of life, take big bites. Moderation is for monks.”
Old 01-13-2018, 05:00 PM   #3
bradley paul
thank you for responding so quickly. So is a masonry mix the same as the quikcrete N Mortar Mix i find on the lowes website? Or is it the type S cement mix what you are referring to? I see so many cement and masonry mixes, that I kinda confused as to whether they're the same thing, very diff or close to the same.
brad
Old 01-13-2018, 06:45 PM   #4
The type S will work fine.
Type M -- 2500 PSI
Type S -- 1800 PSI
Type N -- 750 PSI
Type O -- 350 PSI
Old 01-13-2018, 09:58 PM   #5
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
I have a question since you got the psi's out there for us. What does psi represent when talking concrete or mortar?
I always thought that it meant that an inch of type m weighed 2500 pounds.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Shady at Best is online now   Reply With Quote
Old 01-13-2018, 11:28 PM   #6
wwhitney
That represents the compression strength of the material. I.e. if it is 1000 psi, then a non-slender column (so we can ignore buckling) of the material that is 1 inch square in cross section should support 1000 pounds without failing. Strength in tension or flexure is much less (for these materials).
Cheers, Wayne
Wayne
wwhitney is online now   Reply With Quote
Mud shower with pvc liner - correct order for floating walls, curb and final mud bed? Michael Kehoe Tile Forum/Advice Board 41 09-09-2017 08:20 AM
Crumbling grout and huge gap between curb sill and tile. How to correct? Kevin993 Tile Forum/Advice Board 17 06-09-2015 08:15 AM
remove/reset granite curb cap to correct slope fmoo Tile Forum/Advice Board 8 05-15-2013 02:57 PM
Tiling a varying-height shower curb; Penny tile OK on top of curb? smcquaid Tile Forum/Advice Board 6 01-07-2012 09:02 PM
Correct thinset to use, correct edging to use? ss3964spd Tile Forum/Advice Board 3 07-26-2005 11:30 AM
