Old 01-13-2018, 11:30 AM   #1
vortech91
quick subfloor question
I have 3/4 x 6 planking on a 45degree angle to joist. Deflection calculation is fine. Ive read that I should put 1/2 plywood down then uncoupling (either cement board/ liquid underlayment, or ditra mat. Problem is the 160 square feet kitchen that I want to tile opens up to hardwood flooring layed on the same 3/4 x 6 planking and I would like to keep the transition to the hardwood even. Is there anyway that I can get proper underlayment and uncoupling for tile in 1/2 inch total. I was thinking 1/4 inch "plyfloor" underlayment plywood from menards. then 1/4 inch backerboard? That would allow me to be flush with the hardwood floors. Thoughts?? thanks
vortech91 is offline   Reply With Quote
Old 01-13-2018, 04:23 PM   #2
rmckee84
The thinnest ply you could use would be 3/8" but finding a quality exposure grade 1 ply in 3/8" can be difficult at times. I wouldn't go less than 1/2" personally. 1/4" won't do you much good in this case.
Ryan McKee
Old 01-14-2018, 12:41 AM   #3
Obo2
Ditra is only 1/8" installed. Backer board would be thicker.
15/32 ply and ditra gets you just barely over a half inch.
Nick
Obo2 is offline   Reply With Quote
Old 01-14-2018, 06:48 AM   #4
First I would want to know the spacing on the joists before recommending a plywood thickness. But I believe the thinnest you can use over plank flooring is 1/2".
Quick wonderboard subfloor question evo2turbo Tile Forum/Advice Board 1 04-20-2009 12:29 PM
Need quick response - subfloor question james36 Tile Forum/Advice Board 8 09-23-2007 10:21 AM
subfloor quick question spike Tile Forum/Advice Board 2 01-21-2007 04:44 PM
Quick subfloor question mkrosen Tile Forum/Advice Board 15 11-28-2006 02:27 AM
Quick Subfloor Question dmilamj Tile Forum/Advice Board 8 09-14-2006 09:39 AM
