Old 01-12-2018, 02:17 PM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Kerdi shower curb vs kerdi Board curb
Hey guys. I am putting together a bid and looking through the schluter price list. I am putting together a kerdi shower kit because i am planning on using kerdi board for the walls.
Looking at the curbs. I can get the curb made out of kerdi board for a few bucks more than the regular foam curb. Anyone know a reason why using the regular foam curb would be better than using the kerdi board curb? All I can see is that I will still need to seal the seam where the 2 curbs come together, it's a 5 foot curb.
Edit. I think I see something. Maybe this is overkill. I Add slope to the top of the regular foam curb when I am covering it with membrane. I fatten up the thinset just a bit.
The tile will be sitting directly on top of the kerdi board curb. Of course the tile will have some slope towards the shower. But i always worry about the water that might get past the tile and rest on top of the curb.
Or am i over thinking it?
Your thoughts?
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 01-12-2018, 02:57 PM   #2
Winndustries
If you do a lot of Schluter showers it may be worth buying a sheet of 2" board and making curbs out of it. Depending on the size of the curbs you can a lot of them made from one 8' sheet
Michael
www.winndustries.ca
Winndustries is offline   Reply With Quote
Old 01-12-2018, 03:46 PM   #3
t2jeff
If your already using kerdiboard for the shower, we don't you just make your own from the scraps? The advantage to not buying a premade one is you can make it any height, thickness, and length you want. And, you can cut the correct slope on the top of the curb........
Jeff
t2jeff is offline   Reply With Quote
Old 01-12-2018, 04:04 PM   #4
Shady at Best
Tyrone shoelaces
I am too anal to make the curbs/ niches. The hour it takes to build one is not worth dealing with the seams.
Lets say that i do build the dam. Would you build it out of kerdi board or would you cap stacked 2x4? Do you use kerdi band at the seams or kerdi fix?
Travis
Old 01-12-2018, 06:44 PM   #5
You want to seal seams, screw penetrations, and edges with Kerdiband. You can use KerdiFix to anchor things, but thinset is lots cheaper.
Old 01-13-2018, 08:51 PM   #6
Shady at Best
Tyrone shoelaces
So this puts me right back at why i buy the premade niches and dams vs building them.
Travis
Old 01-14-2018, 06:04 PM   #7
Redlands Okie
Once completed i see either foam or premade as fine. Pick the one that fits you budget or time frame or is available.
Robert
Shower Dam/curb. Kerdi board or kerdi membrane over sheet rock? Shady at Best Tile Forum/Advice Board 11 01-20-2016 09:44 AM
Kerdi-Board for curb material? QualityTileGuy Tile Forum/Advice Board 6 01-09-2014 04:07 PM
Kerdi-board curb? surfcraft Tile Forum/Advice Board 28 02-19-2013 10:22 PM
Kerdi Board Curb Question jbaskins16 Tile Forum/Advice Board 2 09-18-2011 07:50 PM
A shower curb with cement board and Kerdi trihai Tile Forum/Advice Board 4 04-30-2007 01:41 PM
