Old 01-10-2018, 11:09 AM   #1
jstonemo
Mosaic tile on stair riser advice
I am planning on installing mosaic tile on interior stair risers, but when I pulled off the carpet I see that the risers are particle board. I am wondering if the risers need to be removed and use something else like 1/2" backerboard or plywood or if the particle board is good since it won't be seeing foot traffic like a floor would. I have some left over Redguard that I can put on the particle board if that would make any difference.
thanks
John
jstonemo is offline   Reply With Quote
Old 01-10-2018, 06:53 PM   #2
Is the plywood stable? Strong? Flexible?
Old 01-11-2018, 09:21 AM   #3
Hi John,
I think Paul missed the part about particle board. It'll have to come out. You'll need a really strong and stiff base for your tile. 3/4 inch plywood would be the minimum, and then I would suggest a tiling membrane over that.
Old 01-12-2018, 09:09 AM   #4
jstonemo
Thanks, that’s what I figured. Already have the 3/4” ply cut down ready to install.
John
Stair riser height puzzle, new flooring brings up code issue CCDIYer Tile Forum/Advice Board 7 02-27-2014 10:28 AM
Stair riser grout Nannette Tile Forum/Advice Board 8 10-27-2013 08:47 PM
Stair Riser to Landing tile transition KurtH56 Tile Forum/Advice Board 5 09-30-2012 11:56 AM
Tile on 6"x6" sides of each stair riser?? Elkski Tile Forum/Advice Board 13 06-03-2010 09:55 AM
Mosaic/Tile exterior stair risers? KiviMom Tile Forum/Advice Board 5 03-20-2008 09:45 PM
