Old 01-10-2018, 07:42 AM   #1
jwil04
Cheapest Kerdi Board Supplier
I've been looking to order Schluter Kerdi Board and I'm wondering where most of you order it from? Locally, it is about $100 per 4x8ft sheet at Floor&Decor.
Jared
jwil04 is offline   Reply With Quote
Old 01-10-2018, 08:40 AM   #2
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Stay away from f&d.
You should be able to easily find it for 80 a sheet, flooring/ tile stores sell it for $64 a sheet in my area. I suggest that you go to a REAL tile store. That doesn't include floors and decor. Yes, i am talking the 4x8x1/2 sheet.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 01-10-2018, 10:23 AM   #3
jwil04
Any suggestions on a "real" tile store in the Houston/Katy area?
I guess this should be directed towards Houston Remodeler or any other Houston area members...
Jared
Old 01-10-2018, 12:59 PM   #4
Shady at Best
Tyrone shoelaces
I called a few places in your area. You will probably need to go to f&d.
Travis
Old 01-10-2018, 01:52 PM   #5
jwil04
Wow, thanks. I have done some legwork in trying to find stores that seem more legit than f&d but haven't been impressed with any in the area.
Jared
Old 01-10-2018, 02:25 PM   #6
Wahoo
I'm in the same boat here in Austin. Can't find it anywhere other than at F&D for $100 for the 4x8x1/2"
Peter
Wahoo is offline   Reply With Quote
Old 01-10-2018, 05:06 PM   #7
workhurts
I was about to ask what the benefit was to using the board but then did some quick math. Seems like you can do cement board and regular Kerdi for about $2 or less per square foot whereas this is closer to 2.5-3.0 per sq ft?
A bit more expensive on top of already expensive Kerdi application.
Any other benefits in addition to saving time?
Ali
Old 01-10-2018, 06:31 PM   #8
Mathman
Much easier install. Thinset only needed for the bands at the joints. Easy to work with, even easier than drywall. Very little mess.
Kirk
Mathman is offline   Reply With Quote
Old 01-10-2018, 06:49 PM   #9
Shady at Best
Tyrone shoelaces
The board itself will not be destroyed if it does get wet. Drywall will swell and grow mold.
Less labor to install. Adhering kerdi membrane is easy but difficult.
Potentially less seams with 4x8 sheets.
More info along these lines
https://r.tapatalk.com/shareLink?url...0&share_type=t
Kerdi questions, membrane vs. board
Travis
Old 01-10-2018, 08:53 PM   #10
There are very few Pro 4x8 dealers in Houston. Ustah be BPI carried it but no more.
When Laticrete comes out with their 4x8's I'll be getting an entire pallet, putting the excess into general inventory
Old 01-11-2018, 12:57 PM   #11
RichVT
Vermont Remodeling Contractor
I can lift a 4 X 8 sheet of Kerdi Board with ONE FINGER. Seems like a pretty good benefit to me.
Rich
RichVT is offline   Reply With Quote
Wall Tile Backer Board: Hardie, DensShield, Kerdi Board and others: Thoughts? machinemanjr Tile Forum/Advice Board 14 04-21-2017 04:40 PM
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
Whats the cheapest you ever took a job for? HMDuplec Professionals' Hangout 194 03-20-2014 01:25 PM
Question? "Best"/cheapest place to buy kerdi shower Biggamecbc Tile Forum/Advice Board 2 08-15-2010 08:59 AM
