Old 01-09-2018, 09:39 PM   #1
jg1967
Shower Flange and subfloor
I want to add additional plywood to existing subfloor for support but the shower flange has already been installed. So if I add say an additional 3/4 inch plywood then flange will be below subfloor. How will this effect the liner installation?
Jeff
jg1967 is offline   Reply With Quote
Old 01-09-2018, 10:07 PM   #2
Got pics?
Of the drain as well
Old 01-10-2018, 07:31 AM   #3
jg1967
No Pics
Sorry, I am a couple hours away from the house right now. It is a 3 piece drain. Probably should have mentioned that before.
Jeff
Old 01-10-2018, 09:50 AM   #4
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Assuming drain is at correct level with current subfloor, you'd need to move it vertically the thickness of additional subfloor material. Pretty easy in most cases.
Peter
Shower flange subfloor issue David22585 Tile Forum/Advice Board 8 09-23-2014 12:16 PM
flange entender - concrete subfloor funnyguy Tile Forum/Advice Board 1 11-07-2010 02:56 PM
Toilet flange on subfloor (with pics) MikeKarina Tile Forum/Advice Board 13 06-12-2009 04:17 PM
Broken flange & new ply subfloor kernal Tile Forum/Advice Board 5 01-02-2007 11:01 AM
Subfloor to flange bottom..what ply, cbu thickness to use? lithnights Tile Forum/Advice Board 6 03-22-2006 10:40 PM
