Old 01-09-2018, 03:23 PM   #1
drfeno
Where to caulk vs grout
I'm building a 30 by 60 shower stall, 3 sides, and a sliding glass door. the tile will go all the way to the ceiling. I wont be grouting for a couple days yet. I don't do a lot of tile work, but I basically do everything myself. I'm told I need to use caulk instead of grout where planes change, like in the corners of the stall. My question is, do I need to caulk along the cieling line (seems like a cleaner solution than grout) do I also need to caulk where the outside curb tile meets the floor tile, and under the slight drip edge on the curb?, around the shower floor where it meets the wall tile? All these areas change plane. I'm just looking for best practices.
drfeno is offline   Reply With Quote
Old 01-09-2018, 04:17 PM   #2
Essentially, yes to all of your questions. Now, some people get by with using grout at changes of plane. It can be risky and is somewhat dependent on the maximum temperature swings you may experience - the other thing is moisture content if there's wooden substructure...might be fine for a long time, then, you hit a day when the a/c or heat are off, and the temperature extreme causes an issue, or you get a leak somewhere or it rains for days on end, and the humidity is pegged at 100%. My preference is to use an engineered joint (profile) there. Caulk can last a long time, but usually needs to be redone on occasion. A profile is a lifetime endeavor, and doesn't lead to a cleanup issue if you get some caulk where you don't want it, or don't get it as smooth as you might prefer. Unfortunately, though, they must be installed during tiling, so, you're stuck with caulk now.
Old 01-10-2018, 07:41 AM   #3
drfeno
I may need another tube of caulk, I also have a niche with a shelf. I'll attempt to get the caulk as neat as possible. I did use profiles for ending the tile at the wall, and the outside corner of the plumbing wall. They seem to work pretty well.
caulk, no grout? rudyhesse Tile Forum/Advice Board 6 11-13-2010 01:33 PM
color caulk to use, and caulk or grout first? muscat Tile Forum/Advice Board 6 06-29-2009 11:23 PM
Inside Corner Grout? Caulk vs Grout? Brion Tile Forum/Advice Board 11 08-25-2008 06:52 PM
Use only caulk or grout then caulk CalBear Tile Forum/Advice Board 17 07-04-2004 12:04 PM
Re- Grout before Re- Caulk? sakendrick Tile Forum/Advice Board 5 03-12-2004 08:15 PM
