Old 12-12-2017, 01:27 PM   #1
tjschultz2011
Using DitraHeat on the shower floor
I'm in the middle of my bathroom conversion/shower build and I would like to use DitraHeat on the floor of my shower and top surface of my shower bench if possible. I'm planning to use the kerdi system throughout the shower along with a 48"x72" kerdi shower pan. I can't seem to find very much info regarding the use of DitraHeat in the shower. I imagine it would have to be covered with thinset and kerdi after the cable is in place? I will be using DitraHeat throughout the rest of the bathroom and I figured it would be nice to have in the shower too on these cold Wisconsin winter mornings. Is this an option for me and, if so, what is the step by step process of making it happen?
TJ
TJ
tjschultz2011 is offline   Reply With Quote
Old 12-12-2017, 01:44 PM   #2
MisterJJ
LMGTFY
Joe
MisterJJ is offline   Reply With Quote
Old 12-12-2017, 02:53 PM   #3
rmckee84
It is an option, and your on the right track. I would just contact schluter and get their specific requirements on it. I havent done one but I know alot of guys have.
Ryan McKee
Old 12-12-2017, 07:01 PM   #4
page 11
Old 12-13-2017, 11:43 AM   #5
tjschultz2011
Ok, perfect. Thank you guys for the info and links. The ditraheat manual answers a lot of my questions such as how to go over the curb and bench in the shower. Looks like they recommend routing out a groove on top and sides of the curb for the cable to sit in. I assume this would be the same to get the cable up to the top of the bench.
TJ
Old 12-14-2017, 11:08 AM   #6
TJ,
You could heat the front of the bench as well.
Old 12-28-2017, 08:20 AM   #7
tjschultz2011
A couple more questions regarding the use of ditraHeat in the shower now that I'm getting close to being ready to install everything:
1. How do I handle where the ditraHeat and the bonding flange for the drain meet? Do I run the ditraHeat righ up to the edge of the flange and then go over it with kerdi like normal or do I run the ditraHeat underneath of the flange before setting it?
2. What type of thin set would be used for each layer in this system? I know Schluter says to use unmodified under the ST shower tray and in between the ST shower tray and the kerdi, but what if I'm using ditraHeat inbetween the kerdi and the tray? What type is used under the ditraheat, under the kerdi, and under the tiles?
3. I'm planning to use a separate cable for the ditraHeat in the shower that will just cover the square footage within the shower and another cable for the rest of the room. For the one in the shower, what's the best way to get the cable from in the wall to inside the shower? I've seen a lot of people use a conduit that runs from the box to a small opening where the wall meets the floor but this would obviously not be waterproof so how should I handle this in the shower? Start the cable on the outside of the shower and then run into the shower right away using the method above to get over the curb?
4. Because I'm using a two cable system with both cables running to the same thermostat, I wouldn't want to put a heat sensor in the shower, correct? I would think that the warm water would cause the thermostat to turn off the heat for the whole room because of the warm water in the shower.
TJ
TJ
Old 01-11-2018, 10:29 AM   #8
tjschultz2011
Anyone have experience with this?
-TJ
TJ
Old 01-11-2018, 11:56 AM   #9
hfxjohn
probably best to call Schluter, they can answer those questions.
john
hfxjohn is offline   Reply With Quote
Old 01-11-2018, 07:06 PM   #10
The safest thing is to call their tech support line. But, if I were going to do this, I think I'd run the DitraHeat membrane up to the edge of the hole, then treat that like the top of the pan, install the drain, then install the Kerdi over it all and up to the inner edge of the drain's bonding area.
Otherwise, you'd have a step in the pan up to the drain. I suppose you could build that up, but it's probably not worth it.
Concrete shower floor - barrier free - linear floor drain wcontractors Tile Forum/Advice Board 4 08-15-2017 12:32 PM
317/333 Under DitraHeat RRGuy Tile Forum/Advice Board 3 06-06-2016 10:21 PM
DitraHeat recommendation JReid Tile Forum/Advice Board 11 05-19-2016 09:40 PM
Marble Shower Floor - Mosiac tile floor wet underneath? Charlie Hesson Tile Forum/Advice Board 11 03-23-2014 05:41 PM
Need to replace a tile floor in shower but all concrete came out to dirt floor. HollandConstructionServ Tile Forum/Advice Board 11 06-25-2008 10:13 AM
