Old 01-10-2018, 06:58 PM   #1
tyscott
Tyler's Bathroom Renovation
Hi guys. My coworker Steve in Denver told me you guys would give me the best advice for my full bathroom remodelling project. I've never remodelled a bathroom before, so keep that in mind.
Currently, I'm trying to plan out which waterproofing material I will use for the tile surround above the tub.
1. I wanted to know what your opinions on DensShield is.
2. If I do choose to go with it, how do I waterproof the corners?
2a. Can I just use a 5" wide USG Durrock membrane?
2b. Or perhaps the Kerdi equivalent?
3. How do I waterproof the screws that go into the studs?
3a. Do I countersink them and put caulking over it?
3b. What caulking would I need? Kerdi fix? Plain 100% silicone?
4. What other waterproofing strategies would you recommend and why?
Tyler
tyscott is offline   Reply With Quote
Old 01-11-2018, 12:26 AM   #2
Steve in Denver
Steve in Denver's Avatar
What, has nobody heard of DensShield?
(Bump)
Steve
Steve in Denver is offline   Reply With Quote
Old 01-11-2018, 07:03 AM   #3
Welcome to the forum, Tyler.
First, just to clarify, this is just a tub with no shower, correct? If it's a shower that's a different ball game.
I'm not a fan of denshield, but if it's done properly it can work. I think they recommend their sealant over the screw holes and seams. The problem I have with Denshield is the gypsum core, so one little slip-up and it's trashed by water.
I would just use a waterproofing like Redgard over a cement board like Durock or Permabase. Everybody has their preferences, it's just important that you use the one you have chosen according to manufacturer's instructions.
Old 01-11-2018, 08:41 AM   #4
tyscott
Thanks Kevin,
To answer your question, it is a tub and I want to do a tile surround.
When you use redgard, how do you waterproof the corners?
Tyler
Old 01-11-2018, 09:09 AM   #5
Hi Tyler,
I would not use Denshield.
With RedGard you use backerboard tape and thinset in the corners. Flatten the thinset as if you were taping drywall. The RedGard goes over it. Two coats of RedGard.
Tyler's daughter's bathroom build-along OneStaple Tile Forum/Advice Board 26 01-03-2018 10:45 PM
Tyler's half bath OneStaple Tile Forum/Advice Board 25 02-10-2017 11:43 AM
Tyler's master bathroom build-along OneStaple Tile Forum/Advice Board 312 01-09-2017 09:25 AM
Tyler's bathroom build-along (with questions as I go) OneStaple Tile Forum/Advice Board 217 10-10-2014 12:58 PM
Bathroom renovation Clive Tile Forum/Advice Board 8 05-28-2007 03:49 PM
