Old 05-19-2008, 08:41 PM   #1
DJMAHE19
Any advice on How to remove Pencil Marks from Porcelain Tile with a crackle finish?
Does anyone have any advice on How to remove Pencil Lead Marks from Porcelain Tile with a crackle finish?
DJMAHE19 is offline   Reply With Quote
Old 05-19-2008, 09:11 PM   #2
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Hello and Welcome, DJ!
Gotta first name??
Have you already grouted your tile? If not, some pencil marks will go away during the process, and if it doesn't, you can rub hard with wet grout packed on one corner of your sponge till it does. If you've already grouted, try using a Scotchbrite pad or similar with water. Be careful with colored pads and your grout.
Brad
Old 05-19-2008, 09:35 PM   #3
or a little soft scrub or mothers polishing wax if you have them in your kitchen or garage.
dont get them in the grout and not to be used on polished porcelain.
Old 05-20-2008, 07:19 PM   #4
PrecisionFlooring
Custom Hard Surfaces
Mr. Clean Magic Eraser works fantastic for stuff like that.
When my kids were younger, we had a need to find out answers such as these
Paul
Do it right or don't do it at all....
PrecisionFlooring is offline   Reply With Quote
Old 05-20-2008, 07:33 PM   #5
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hello DJ,
I've had the best luck using non-sanded grout (to match the color of the tile) to use as a rubbing compound. If you use your normal grout, and it isn't a match to the body of the tile, the pigment will embed in the cracks and leave you discolored areas.
Crackle-glazed tile should always be sealed prior to grouting.
Shaughnn
