Old 04-20-2017, 09:43 PM   #1
sd6000
Grout colorant difference?
I have some grout I want to change color of. I've read many posts on here about aquamix and it sounds great for my situation.
My local home depot sells grout renew by custom building products. Aquamix is made by custom also, but difficult to locate.
Question being are these the same products just labeled and marketed different? I have no problem paying more and ordering aquamix if it is worth the extra. I only consider grout renew because it's readily available locally.
If anyone has a good place to order aquamix colorant to suggest, I would appreciate it!
Bryan
sd6000 is offline   Reply With Quote
Old 04-21-2017, 04:38 AM   #2
claycarson
Commercial Cleaning and Maintenance
I've used both, both worked well.
In fact, I've used that type of product made by 5 different manufacturers, and all of them performed perfectly as advertised. So now I go by color preference and availability.
Sent from my SM-G920T using Tapatalk
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Old 05-16-2017, 08:30 AM   #3
Hi Brian,
I agree with Clay. Either product will work fine. Grout "colorant" is a topical product (paint). It will wear eventually in traffic areas and may need to be renewed or touched up at some point. I do recommend it, though.
Grout Stain, Grout Paint, Grout Colorant: Product Recommendations Needed RedRightHand Tile Forum/Advice Board 3 02-19-2013 02:13 PM
Considering grout colorant lor_68 Cleaning, Restoration and Sealing 15 02-28-2011 07:16 PM
Grout colorant? gler Tile Forum/Advice Board 1 05-10-2010 04:42 AM
Which grout colorant is best? Joerg Tile Forum/Advice Board 3 02-04-2005 05:27 PM
grout colorant Leah The Mud Box 3 12-04-2002 10:52 AM
