Old 06-16-2017, 12:06 PM   #1
briones
spray sealer vs applied sealer
Is there a differance between using spray on sealer versus hand applied sealer with a foam brush on tiled shower walls? Thanks.
luis
briones is offline   Reply With Quote
Old 06-16-2017, 10:10 PM   #2
Welcome to the forum, Luis.
That depends on which sealer you'd apply with a brush. If it's a recognized good quality sealer like Sealer's Choice Gold or Miracle 511, then I'd say that they would likely perform substantially better than the spray-on stuff. If the brush on sealer is a cheap $10 bottle of sealer, than I think both the spray stuff and the cheap brushed stuff would perform equally poor.
A few years ago, there was a whole bunch of folks that suffered serious medical problems from breathing in the vapors from a particular spray on sealer. I believe it was called "Stand 'n Seal". While I'd like to think that the problem was fixed, I'd also would have thought that the folks making the problematic sealer in the first place would have figured that out before so many people had to be hospitalized.
Applying a traditional sealer with a foam brush is easy and not very time-consuming. And it gives you the ability to pick out a much higher performing sealing product.
EDIT: I found the old thread about Stand 'n Seal.
Old 06-18-2017, 10:23 PM   #3
prodjsaig
Good to know that the aerosol version can be hazardous. Im fairly new to grouting and tile in general and have a question about sealing. I have done 2 floors and sealed with both water based and oil.
I used a small artist brush and coated it on and basically had just a few areas to buff off. with the oil based I had to reapply the sealer to get some streaking off.
now with something like a shower and a spray bottle or foam brush can you just go to town on the wall. let it dry and the buff it? or do you have to spray it then wipe the tile right away? or just use the foam brush and becareful and not let it drip?
Colby
prodjsaig is offline   Reply With Quote
Old 06-19-2017, 05:00 PM   #4
Assuming man-made tiles with a non-porous surface:
A foam brush is one of the quickest tools to get the sealer where it belongs. I'd avoid wiping or spraying intentionally over the whole wall. Too time consuming to remove the excess sealer from the face of the tiles and wasteful of the sealer.
Dip the foam brush in a shallow amount of sealer (let's say 1/2" of sealer in a small container). Mush the brush on the side of the container to remove the excess sealer from the brush that's dripping out. Then apply along the grout lines. As you paint, get in the habit of flipping the brush 180 degrees every several seconds to keep excess sealer from dripping out of the brush. Work in manageable sections at a time. Concentrate on an area that you can coat, allow to dwell 4-5 minutes and then buff dry before any of the sealer dries in its own. Use a clean, white, absorbent rag to polish the excess sealer from the face of the tiles. It is very important to get the tile 100% dry and clean. It helps to work in great lighting conditions.
Old 06-20-2017, 02:50 PM   #5
prodjsaig
Thanks for the help. I have another floor to tile and also have to seal a hearth and entryway shortly. the technique or even the process isn't quite clear on the bottles.
getting some on the tiles isn't a big deal which is what I was critical about at first
Colby
Sealer applied over grout haze cscott64 Cleaning, Restoration and Sealing 6 04-05-2010 11:59 PM
Can Enhancing Sealer be applied over regular sealer? sqerlygirl Cleaning, Restoration and Sealing 1 08-22-2007 04:19 PM
spray sealer death? wopachop Tile Forum/Advice Board 8 02-16-2007 10:48 AM
Does new grout need to be cleaned before sealer is applied? hi50 Tile Forum/Advice Board 5 04-14-2004 07:43 PM
Grout faded when sealer applied msodja Tile Forum/Advice Board 10 01-14-2004 08:41 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
