Old 03-13-2018, 12:02 AM   #1
arhuranna
Onyx shower base with tile wall
I'm going to install a Onyx walk in shower base and tile the walls. I will be using Hardibacker 500 on the walls. Onyx recommends 1/8 inch spacing between the base and stud wall and the Hardiebacker should be 1/4 inch above the base. What would be the best the best way to proceed, vapor barrier behind the Hardiebacker or use Redguard applied to the Hardiebacker? Thanks for the help.
Mitch
arhuranna is offline   Reply With Quote
Old 03-13-2018, 10:32 AM   #2
Welcome to the forum, Mitch.
A surface applied waterproofing layer is always superior to one that is behind the wall board.
Old 03-13-2018, 11:49 AM   #3
arhuranna
Thanks, that's the decision I've come to.
Mitch
Wall tile substrate with a cast iron shower receptor/base Leah F. Tile Forum/Advice Board 11 09-12-2017 07:29 AM
Installing a 4'x6' onyx slab in a shower wall JayEtta Tile Forum/Advice Board 2 08-08-2013 10:29 AM
Adhesive to stick Onyx Tile 1x2s to a Glass Shower Wall steveoneal Tile Forum/Advice Board 9 06-13-2013 08:54 AM
Best solution: large gap between shower base and tile wall DaveHyatt Tile Forum/Advice Board 5 03-22-2013 09:56 AM
Installing Crimson Onyx Tile against a Knee Wall. BlinkNowPlease Tile Forum/Advice Board 1 06-06-2008 04:21 PM
