Old 03-12-2018, 03:14 PM   #1
Quick question on a routine topic
This has probably been answered a few times and Ive read a few threads on this topic but hoping someone can offer a little advice
Hardiebacker to Drywall transition.
Hardiebacker wall is flat, shimmed, Im very happy. Drywall unfortunately is not.
The transition from my Hardiebacker to drywall varies from 1/16th" to 1/8th".
The 1/8th" transition seems to be in the middle of the wall.
I plan to feather thinset with mesh tape over the transition. When done tiling Ill finish up with joint compound on the drywall, prime, paint, chalk the seam.
Can you shave down the Drywall a little? It would remove the drywall paper facing. Good or bad idea?
VToutdoors is offline   Reply With Quote
Old 03-12-2018, 03:33 PM   #2
HardieBacker is less than 1/2" thick at 0.42" or a little more than 13/32".
It probably isn't a great idea to try to sand the paper off of drywall. If it has excessive drywall compound, that can come off.
Old 03-12-2018, 04:58 PM   #3
One of the very reasons I don't use Hardibacker on walls.
Old 03-12-2018, 05:31 PM   #4
If you do remove the paper,seal it with coupla coats of oil primer or Zinsser spray oil primer.
Canaris is offline   Reply With Quote
quick question about thinset...need answer quick agoings Tile Forum/Advice Board 13 04-28-2006 06:19 AM
off topic question randy5150 Tile Forum/Advice Board 3 04-16-2006 11:04 AM
off topic question v1rtu0s1ty Tile Forum/Advice Board 4 12-01-2005 02:52 PM
Off Topic Electrical question if i may? TomR1972 Tile Forum/Advice Board 38 02-22-2005 10:12 AM
A quick hello and a quick question of tile and stairs. bmkiss67 Tile Forum/Advice Board 14 07-30-2003 09:09 AM
