Old 03-12-2018, 07:00 AM   #1
Shower corner input requested..
Using Kerdi board on shower walls and have a short wall that will be plastered on one side and Kerdi on other. My concern is where they meet at corner of a 2X4 wall. This wall will have a shower door mounted on it. Should metal be used or can I do the outside corner with Kerdi since they will be tiled. My concern is how to mesh the Kerdi to a plastered corner? It is a short wall. Is it better to Kerdi both surfaces ( waterproof with Kerdi band) and omit the plaster altogether?
Chairandy is offline   Reply With Quote
Old 03-12-2018, 10:05 PM   #2
Kerdi can be wrapped around an outside corner that is getting tile on the two adjacent surfaces.
But I’m not following which surfaces will be what. Can you clarify a bit?
Old 03-13-2018, 07:10 AM   #3
Clarification on question..
The 2 by 4 wall in question is where shower door will be hung. It is perpendicular to inside wall of shower. It will have tile on both sides ( in and out of shower)and end. Kerdi board panels will be used and would like to avoid any build up if metal is used on outside corners. Can i wrap the corner without metal .... just use Kerdi board and apply Kerdi ban ?
Old 03-13-2018, 08:04 AM   #4
Carbidetooth's Avatar
No need for drywall corner bead if both surfaces are to be tiled.
I'm unclear on how the door factors into equation. Perhaps a drawing or photo would be helpful.
Feedback Requested on Unique Shower Remodel Plan That New Guy Tile Forum/Advice Board 2 09-21-2017 08:50 AM
Advice requested for tiling shower with bench hajdukjd Tile Forum/Advice Board 4 04-05-2017 06:23 AM
Broken tile on shower floor - Advice requested. victorhall Tile Forum/Advice Board 5 07-08-2009 07:11 PM
Accessible shower challenge (long, advice requested) ChrisHutchinson Tile Forum/Advice Board 6 05-19-2005 04:44 PM
Career change. Input requested iconfab Professionals' Hangout 10 11-29-2001 04:44 PM
