Old 03-11-2018, 11:07 PM   #1
JodiChris
The Tiling Grandmother
Tub/Shower Hours Dilemma
Hi, I'm new here looking for help sorting out the cost of a tile project that seems to be way over budget. I managed this job for a friend and total hours (at $50/) now stands at around 150 for a standard 30x60 tub/shower. This includes reframing, new framing, cement board and everything else.
Here are the complicating factors:
1) The back wall is out of plumb about 1.5" in 8', the wall tilts toward the open side of the tub. This was a replacement-in-kind project so removing the tub, reframing the walls and redoing the plumbing wasn't an option.
In fact, the entire building is racked this way, I'm thinking maybe it went through the 1989 earthquake here in California.
2) Alot of the framing around the plumbing and at the back wall was standing proud in spots and many studs needed to be ground down to accommodate the ltf's.
3) The large format tiles (12x24) were difficult to taper from 0 to 3/16", maybe due to saw problems or ... I dunno. There was a lot of swearing and a lot of chipping.
4) There was an inline niche (see attached photo) that needed precise measuringand framing to come out right.
5) The mosaic tiles used at the sides of the niche all had to be set individually because they were uneven on the mat and the spacing was off with respect to fitting them into the niche sides in a pleasing way.
6) And those same tiny mosaic tiles have some impressed designs which are grout catchers. It's either dig the grout out of the crevices or cover with something like tape before grouting - which means more time. Oh, and there are lots of them, in one of the photos, what look like bright blue tiles are the ones that were taped to keep the grout out.
7) As you can see, there was a horizontal border of the mosaic tiles and, since they were thinner than the field tile, they were thinset to an additional substrate before they were applied to the walls.
Other than that, everything was perfect
My questions:
-> How long do you think it should take to complete a project with these kinds of problems?
-> What's the secret for getting clean cuts on tiny tapers across the 12" end of a tile? (thank God they were laid horizontally!)
-> How would pros deal with the mosaic crevices? I considered rubber cement to cover those tiles...
-> What's the best way to even out a surface when there are tiles of different thicknesses being used together?
Thank you for bearing with me, I've queried many folks about this and have all kinds of answers, none of which are the same. I want the installer and the owner both to be treated fairly, that's why I'm asking. And I don't mind learning a thing or two in the process, either.
Jodi
JodiChris is offline   Reply With Quote
Old 03-12-2018, 01:21 AM   #2
Welcome to the forum, Jodi.
Just to clarify, are you saying this project took the equivalent of one person working almost four 40-hour weeks to complete?
I mean, I'm slow at setting tile, but.....
Old 03-12-2018, 04:37 AM   #3
evan1968
Not So Senior Contributor
evan1968's Avatar
150 hours?? Seriously?
1-7 you posted are not complicating factors that warrant 150 hours. We run into any one of these on almost every job.
Unless there is a vapor barrier behind that cement board, I'm not seeing any waterproofing. Whatever you do don't reply with "we are going to seal the tile and grout"
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Old 03-12-2018, 01:26 PM   #4
JodiChris
Arrow
Yes, it's a little more complicated than that, but, essentially that's what happened. It was pretty hard to watch it happen.
Jodi
Old 03-12-2018, 01:57 PM   #5
JodiChris
Evan, thanks for your reply. Yes, there is a vapor barrier behind the cement board. Given all these factors in a single job, how long do you think it should take to complete it?
Jodi
Old 03-12-2018, 02:14 PM   #6
A week or so should be plenty.
Old 03-12-2018, 02:27 PM   #7
JodiChris
Thanks, Kevin. I heard maybe a week and a half from someone I trust so that's a good confirmation.
Jodi
Old 03-12-2018, 03:18 PM   #8
evan1968
evan1968's Avatar
Yep. One week.
Someone made a career out of that shower.
Craig
Old 03-12-2018, 03:19 PM   #9
JodiChris
Question
Any others want to chime in on the time question?
And, any suggestions about the rest of the questions (repeated below) would be much appreciated!
Thank you!
Jodi
Old 03-12-2018, 03:23 PM   #10
JodiChris
Thanks Craig/Evan I think it was a matter of skill and experience rather than anything purposely done to create a money pit!
Jodi
Old 03-12-2018, 10:53 PM   #11
tatumjonj
It's fine that he took 150 hours, but it doesn't sound like he had the skill or experience to charge $50/hour. $50/hour is for the guy that could knock that out in a week.
Jon
Old 03-12-2018, 11:05 PM   #12
lati_cz
michal
It would take me few days more than week, but I wouldn't need a manager.
Michal
lati_cz is online now   Reply With Quote
Old 03-13-2018, 08:41 AM   #13
Dave Gobis
da Man!
Dave Gobis's Avatar
I had two different guys that did tub areas. Jack was one of the "quick brothers" he would be done in three days. Steve and Terry were artist's, they would be there 5-6 days. That is from a 25 year history running 5 crews.
Old 03-15-2018, 01:19 AM   #14
JodiChris
Smile
Thank you all for your comments, they are very helpful. I can finish my reports now and make recommendations regarding fair market value of the job.
This forum is a great resource inhabited by a friendly bunch of folks, bravo!
Jodi
Same ole shower Dilemma jtubbs Tile Forum/Advice Board 13 11-28-2011 11:11 PM
New Shower Grout looks wet after 48 hours youcan Cleaning, Restoration and Sealing 10 11-11-2010 09:42 PM
Kerdi Shower - How many hours? bathroomremodeler Professionals' Hangout 2 02-23-2008 05:10 PM
Shower Pan Dilemma Quiz Tile Forum/Advice Board 2 12-20-2006 08:50 PM
Shower deck done 24 hours ago and I have some questions jebh Tile Forum/Advice Board 5 11-15-2004 12:09 AM
