Old 03-11-2018, 12:13 PM   #1
Vondon
Hydroban Pan to Wall Transition
Hello,
I'm a homeowner with construction experience but never any tiling. So, I of course decided I should remodel my bathroom with a full tile shower. I've been creeping around on this forum (its fantastic), and following The Floor Elf's guide (which seems legitimate) to a liquid topical shower waterproofing using Hydroban. I've Durocked the walls, built a brick curb, installed a Laticrete flange drain, and just packed my pan so am basically ready to apply Hydroban (after 72 hrs).
My question is, after reading a few Hydroban horrors, would it hurt to thin set and fiberglass tape the pan-to-wall transition before applying Hydroban?
I know Hydroban says it doesn't require fabric for under 1/8th in gap. However the floor to wall transition seems like the most likely spot for a failure and I figure I might as well make it bombproof.
Thanks in advance!
Ethan
Vondon is offline   Reply With Quote
Old 03-11-2018, 12:17 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I wouldn't consider not using mesh tape and thinset at plane changes. Depending on size and configuration, I might also use reinforcing fabric with Hydroban.
Peter
Old 03-12-2018, 07:31 AM   #3
Sharon @ LATICRETE
Sharon @ LATICRETE's Avatar
Yes, you can do this!
Sharon@LATICRETE
Sharon @ LATICRETE is offline   Reply With Quote
Old 03-12-2018, 08:14 AM   #4
Vondon
Great, thanks for the speedy responses.
Ethan
Wall to tub flange transition duanec Tile Forum/Advice Board 1 12-23-2011 09:32 AM
Floor/Wall Transition rmac Tile Forum/Advice Board 3 02-05-2008 02:33 PM
transition from wall tile to painted wall Hickory Tile Forum/Advice Board 3 04-04-2006 11:18 PM
tub-wall transition issue sawzall Tile Forum/Advice Board 9 10-20-2004 06:34 PM
Floor/Wall Transition brianp Tile Forum/Advice Board 3 07-15-2004 04:11 PM
