Old 03-11-2018, 12:01 PM   #1
mksanny
Studs not flat
Hi,
I am attempting to redo the walls surrounding my tub. I intend to install Hardie backer boards to my studs.
When I try to check if all the studs line up so that I have a flat surface to work with, when it comes time to tile, I notice that the corner stud on the back wall is probably about close to an inch recessed from all the other studs on the wall. There is another stud approximately 5 inches from the corner stud that does align with all the other studs on the wall.
All the video's I watch online suggest I do need to screw in the backer board at the corners of the board. It is not considered ok to screw the board 5 inches in and leave the corner without screws, correct?
KS
mksanny is offline   Reply With Quote
Old 03-11-2018, 12:06 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Your assumptions are correct. You need to fur out the corner stud to be in plane with others.
Would it work out OK with mesh tape and mortar? Maybe, but I'd never chance it. It has some track history, I guess, but was not right to begin with.
Peter
Small Floor -> Large Tile and How Flat is Flat? Eldudarino Tile Forum/Advice Board 9 09-23-2016 12:53 PM
How flat is a flat floor? Robert Shelton Tile Forum/Advice Board 16 11-29-2015 01:05 PM
How flat is flat? Filling in subfloor dips RDS Tile Forum/Advice Board 2 06-08-2011 02:18 PM
How flat is flat for SLC- leave good enough alone? 1/4 in 4 feet? luciphil Tile Forum/Advice Board 11 05-07-2009 09:52 PM
best way to tell if floor is level/flat-and other flat surface issues!? acid Tile Forum/Advice Board 9 05-12-2005 10:32 PM
