Old 03-11-2018, 11:19 AM   #1
Tile cutter
I am laying a house floor with 24x24 porcelain glossy tile (3/8" thick) on a diagonal. What would be the best way to cut this tile ?
I haven't seen a wet saw that can cut the 36" and am leary of the score and snap giving a smoothe edge
Any help would be appreciated
Bubba153 is offline   Reply With Quote
Old 03-11-2018, 12:10 PM   #2
Carbidetooth's Avatar
In terms of saw, a bridge saw would do this. Cutting from two directions on a smaller saw could work, but cumbersome. Tile snapper would be an option, but I'd assume the snapped edges would be covered by baseboard and a good big snapper not inexpensive.
If I had to pick one only, the wet saw may prove to be the best all around.
Old 03-11-2018, 06:50 PM   #3
I would agree with Peter. There are some cuts that you just can't make with a snap cutter, such as corners. But you can make most any cut with a saw, albeit having to cut from both ends of the tile to the middle.
If you can find a rail saw for cheap, that would be the way to go. The big box stores don't carry them any more, but you might check the pawn shops if you have the time, or online.
Old 03-11-2018, 10:13 PM   #4
Just to confirm, Wayne: the cut edges are going to be covered by baseboards, right?
tile cutter motorboatinsob Tile Forum/Advice Board 3 02-24-2015 10:24 PM
Tile cutter Sharpen Tile Forum/Advice Board 4 08-19-2014 06:41 PM
Wet Tile Cutter glasscutterlady Tile Forum/Advice Board 3 07-22-2012 08:55 PM
Tile Cutter goliath6262 Professionals' Hangout 31 04-07-2005 07:11 PM
Tile cutter instead of a wet saw? ninemile Professionals' Hangout 19 12-29-2002 04:28 AM
