Old 02-11-2018, 02:08 PM   #16
JMG
Jason
Thanks Kevin. Sorry about that. I knew better than to start another thread!
Your probably right but I might have a hard time if it isnt in stock to order one sheet.
I was wondering if glueing together two sheets of 7/16 would do the trick, using something like gorilla glue and clamping. It's really a pretty small area and unfortunately right around the center drain. I would of course brace the bottom side with 2x to stiffen things up a bit.
Thoughts?
Jason
JMG is offline   Reply With Quote
Old 02-11-2018, 02:16 PM   #17
wwhitney
Best to get the 7/8" OSB to match. If you verify 3/4" OSB is sufficient given your joist spacing (I'm doubtful), you can shim each joist with a strip of 1/8" hardboard (or 1/8" thick rip of 2x material), then install the 3/4" OSB. How are you going to handle the butt joints perpendicular to the joists of your new and old OSB?
Cheers, Wayne
Wayne
Old 02-11-2018, 02:24 PM   #18
JMG
Jason
Thanks for the reply Wayne.
At the butt joints, I will use 2x blocking between, regardless of what I use.
Hopefully I can get a single sheet of 7/8" tomorrow and make life a bit easier :-)
Jason
Old 02-11-2018, 02:26 PM   #19
Since you're using a tray, I think you better get the 7/8". If you were using a mud floor as your base, having the floor a little uneven wouldn't matter. With a tray, it has to be perfectly flat and level.
I'd be concerned about the deflection between the joists with something thinner, as well as getting the height of the patch to match the rest of the floor.
Old 02-11-2018, 02:27 PM   #20
JMG
Jason
Thanks Kevin. I think your right.
Jason
Old 02-11-2018, 02:37 PM   #21
wwhitney
Is your existing OSB in the alcove dead level in both directions? I understand that to be a requirement for the foam trays.
Cheers, Wayne
Wayne
Old 02-11-2018, 04:55 PM   #22
JMG
Jason
Well damn. I'm good front to back (32" depth). Not so good side to side. About 1/4" off with a 6 ft. Level. Not good. Ouch.
Jason
Old 02-11-2018, 04:58 PM   #23
A mud floor instead of the tray would solve that problem, as well as the subfloor issue.
Are you moving the drain?
Old 02-11-2018, 05:38 PM   #24
JMG
Jason
Yes, I'm moving the drain to the center. I need to get rid of the old trap and cap off then tie in a new trap.
I'm ok with a mud bed. I was worried about the added weight given the 24" o.c. I joists (9-1/2").
Jason
Old 02-11-2018, 05:53 PM   #25
Redlands Okie
kerdi foam shower tray over OSB
The Kerdi foam shower tray needs to be applied with thin set under it ? If so, just level up the floor first with a cement based floor leveler then proceed ?
Robert
Old 02-11-2018, 06:08 PM   #26
JMG
Jason
Thanks for the reply Robert. That would be ideal for me right now.
The only problem I can see is installing the drain and not knowing how much wiggle room I have after I plumb the trap. Guess perhaps I could shim up the foam drain spacers to level to find my drain height?
Jason
Old 02-11-2018, 07:48 PM   #27
Redlands Okie
Once you level the floor your in same position as you thought you were to start with.
We usually cut the vertical drain pipe after the base is down.
Is the drain pipe PVC ? If so a tooth cutting wheel on a shaft for fitting to a drill allows cutting the PVC from inside. Works fine.
Could do the same with a drimal tool or die grinder on metal pipe, just take your time.
https://www.homedepot.com/p/HDX-Inte...7516/204277491
Robert
Old 02-11-2018, 08:52 PM   #28
JMG
Jason
Thank you. That makes sense!
Jason
Old 02-11-2018, 09:06 PM   #29
If your trap and drain pipe is not supported from below, when you try to push the drain down to make the joint...it will push the drain itself down. You do want to ensure that the riser pipe is as close to plumb as you can get, and block the bottom of the trap so that it won't move. Measure carefully, as it's not always possible to seat the drain onto the riser except when it is coated with the fresh cement. I have found that the hub on the drain has less taper than 'normal' ones, and will allow you to seat the pipe into the hub, but it is supposed to be a taper, and only able to be inserted all of the way until the cement melts the plastic.
Old 02-11-2018, 11:16 PM   #30
Redlands Okie
Very important points Jadnashua has pointed out. No need to learn the hard way
Metal strapping or plumbing tape, blocks of wood or something.
Robert
Kerdi-shower-st (tray) ckrezler Tile Forum/Advice Board 12 03-09-2013 07:03 PM
Kerdi Foam Shower Pan Adhesive Question vtcrusade Tile Forum/Advice Board 6 12-30-2010 11:05 AM
Leak betweem foam tray and subfloor Caljack Tile Forum/Advice Board 4 07-12-2007 10:02 PM
Foam bench mentioned in Kerdi Shower book - link is wrong GHR Tile Forum/Advice Board 3 06-15-2006 06:34 PM
Kerdi drain near edge of shower and Noble ProSlope vs. Kerdi Tray vs. mud Hickory Tile Forum/Advice Board 8 12-07-2005 03:42 PM
