Old 02-02-2018, 09:32 AM   #1
zzmac
Quartz Tiling Questions
I'm buying some cut 2cm quartzite pieces to clad the Jacuzzi in our bathroom. I haven't removed the old tile yet but I'm assuming there is a wood frame around the Jacuzzi.
The biggest piece of quartzite will be to cover the front panel which is 73" wide by 19" high. I'm guessing the piece will weigh about 125 lbs.
What type of adhesive would be recommended for something like this? I wouldn't want it falling off on someone's foot. :-)
Zeba
zzmac is offline   Reply With Quote
Old 02-02-2018, 10:08 AM   #2
Hi Zeba,
If you're tiling over sheetrock just about any decent thinset will work. Spend more than ten bucks for the sack.
Old 02-02-2018, 11:36 AM   #3
zzmac
I'm tiling over wood.
Zeba
Old 02-02-2018, 02:47 PM   #4
Obo2
you'll want a modified large format thinset.
should be ansi A118.11 so it will stick to the wood and large format due to the size.
although to be sure you are good to go we might need to know what kind of wood and maybe a pic.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 03-11-2018, 11:07 AM   #5
zzmac
Tile over tile? Or not?
Once I have a new heated bathroom floor installed I'll have some quartzite I bought cut into four pieces to clad the Jacuzzi and then have new wall tiles installed.
After taking off the wall tiles (no compliments please lol) I'm wondering if it would be better to leave the Jacuzzi tiling as is and tile right over it with the new quartzite pieces. I imagine the wood frame the builders put around the Jacuzzi isn't the greatest and I'm concerned about damaging it trying to get the tiles off.
Which is better? Removing the old tiles or tiling over them?
If removing the old tiles is better is there any tricks for safely removing them?
Thanks!!!
Zeba
Old 03-11-2018, 02:40 PM   #6
Zeba, let's keep all questions related to this project on this thread so that questions and answers aren't duplicated, and the history is in one place.
Which is better? To tear it all off and start new. Which is easier? Probably tiling over what you have.
The only problem with going over what you have is that you can't be assured that what you have is bonded well, and the new tile will depend on that completely.
Either way, if you decide to go over it, scuff it with a sander, then use a modified thinset that is rated to bond tile to tile.
Is it just plain ceramic tile there now?
Old 03-12-2018, 06:34 AM   #7
zzmac
Yes, it is plain ceramic tile there now.
Zeba
Old 04-11-2018, 01:27 PM   #8
zzmac
"you'll want a modified large format thinset.
although to be sure you are good to go we might need to know what kind of wood and maybe a pic. "
It's plywood.
Zeba
Quartz Threshold and Quartz top for half wall in shower Mr Hunter Tile Forum/Advice Board 1 11-01-2015 07:46 PM
Star Quartz - Quartz lock grout Tileman Packerfan Professionals' Hangout 4 06-29-2014 10:22 PM
Tiling newbie with some questions - tiling over tile, etc rickcr Tile Forum/Advice Board 4 12-05-2010 04:00 PM
Star Quartz - Quartz Lock defective product homeownerbayarea Tile Forum/Advice Board 4 10-08-2009 11:19 PM
Actual Tiling Questions, we may be actually tiling soon.... jlbos83 Tile Forum/Advice Board 5 10-08-2002 04:28 PM
