Old 01-31-2018, 04:47 PM   #31
cngodfather1
OK plywood is down
Hi, I am almost done installing my plywood. The area that I am doing is fairly large. My question is: with 4x8 sheets of plywood and 3x5 sheets of cement board, how can I align the cement board so that the seams from the plywood do not line up with the cement?
Christopher
cngodfather1 is offline   Reply With Quote
Old 01-31-2018, 07:03 PM   #32
wwhitney
Your dimensions are all multiples of one foot, so just offset the first piece of cement board from a piece of plywood by an odd multiple of 6" in both directions. I.e. 6", or 18", or 30", etc.
Cheers, Wayne
Wayne
Old 02-01-2018, 06:51 AM   #33
cngodfather1
Ok cool. That is what I will do. Thank you!
Christopher
Old 02-02-2018, 05:22 PM   #34
cngodfather1
hallway tile
Hi!
I will be putting tile in my hallway. How do I do this when we need to get to the bathroom and bedrooms? 6x36 wood plank tile.
Christopher
Old 02-02-2018, 06:28 PM   #35
Obo2
if you absolutely must use the floor in less than 24 hours there are rapid setting thinsets and grout which would allow you to walk on the floor sooner. These can be problematic for a diyer. you could also just do half of the hallway and then once it's set do the other half or go get a room for the night.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 03-04-2018, 12:08 PM   #36
cngodfather1
just wondering... If i use large format tile thinset and a self leveling system, can a 70 lb dog walk on it if it is not fully cured without a major issue? I can make a bridge for the family, but i doubt the dog will follow it.
Christopher
Old 03-05-2018, 12:02 PM   #37
Can you lay something like a sheet of 1/4" Masonite over the tile? It would help distribute the dog load....
Old 03-05-2018, 07:38 PM   #38
cngodfather1
I would, but the leveling system has the plastic pieces that stick up all over the place.
Christopher
Old 03-12-2018, 04:17 AM   #39
cngodfather1
new pictures
cement board almost done. here are some pics
Christopher
Old 03-12-2018, 04:19 AM   #40
cngodfather1
sorry. not sure why my pics flipped
Christopher
Old 03-12-2018, 06:17 AM   #41
It happens a lot, but don't worry. I can just turn my phone sideways.
Regarding making a path for the family to walk on, sometimes I'll use some rapid setting thinset for two or three rows to accommodate some foot traffic. As for the dog, I don't know what to tell you about that.
Old 03-12-2018, 09:23 AM   #42
cngodfather1
What do you guys recommend for the best Large Format Tile thinset?
I will be installing 6x36 porcelain plank tile on Durock.
Also, if you can list bad brands and stories as well.
Christopher
Old 03-12-2018, 09:54 AM   #43
Canaris
Mapie ultralight. I just finished doing our bathroom... 10x16 wall tiles ,no sag at all.
Canaris is offline   Reply With Quote
Old 03-12-2018, 11:39 AM   #44
cngodfather1
My tile will be floor tile. I am glad your project turned out great!
I was recommended mapei from a friend as well.
Christopher
Old 03-12-2018, 01:21 PM   #45
Hi Christopher,
All of our sponsor tile products companies have special thinsets for large tiles. Check the web sites and mention LFT (large format tile).
Spectralock in stages? jwray Tile Forum/Advice Board 5 05-29-2007 06:40 AM
Grouting in Stages BEERxTaco Tile Forum/Advice Board 3 12-19-2006 07:47 AM
beginning stages mechguy Tile Forum/Advice Board 10 11-24-2006 10:46 PM
kerdi in stages Lola Tile Forum/Advice Board 3 06-20-2005 06:30 PM
grouting in stages bjt8834 Tile Forum/Advice Board 3 04-17-2004 04:11 PM
