Old 03-11-2018, 12:38 PM   #1
AnnG
Uneven spacing of hex tiles on mesh
I just unpacked my special order hex tiles that I planned to install on my shower pan. The spacing of the tiles on the mesh sheets varies from acceptable (just a couple sheets) to passable (several sheets) to horrible (lots of sheets). By horrible, I mean some of the little hex tiles (approx. 1 in. each) are nearly touching, while others are 1/8"+ apart from each other.
This was a special order, and unfortunately, I let the two-week window for returns pass without inspecting things. Plus, I am finally ready to install and want to get this done. Now.
Is my only option to cut the mesh and set each little hex tile manually?
Ann
AnnG is offline   Reply With Quote
Old 03-11-2018, 02:22 PM   #2
Unfortunately, probably yes.
Old 03-11-2018, 02:31 PM   #3
That happens often with those kind of tile.
Now, if you're really lucky, they'll be mounted with water-soluble glue, so when you cut them on a wet saw the whole sheet will fall apart.
Old 03-11-2018, 03:53 PM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
Welcome to our world.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Old 03-11-2018, 06:24 PM   #5
Karls tile Inc
Sometimes if the grout is complimentary to the tile it will hide the the different sized joints. It all depends on how perfect you want it. I have seen sheets from AKDO have terrible spacing and that company is pretty expensive. We install it and adjust as best as we can and grout normally hides the rest.
Karl
Karlstile.com
Old 03-11-2018, 08:04 PM   #6
Before determining if the tiles are good enough, try dry fitting the sheets together first. They might look too bad or they may not even fit together at all. Set them against a straight edge to check them.
2x2 shower floor tiles uneven on mesh gwilson Tile Forum/Advice Board 6 06-28-2015 04:02 PM
Uneven Spacing on Moroccan Tile Backsplash Annica Tile Forum/Advice Board 10 02-15-2014 08:52 AM
Hiding Uneven Grout Spacing In Corner dodgetruck Tile Forum/Advice Board 2 03-28-2008 11:23 PM
cutting 2 x 2 tiles on 12 x 12 mesh maddiep Tile Forum/Advice Board 1 09-06-2005 04:54 PM
Spacing Tiles CTYANKEE Tile Forum/Advice Board 8 09-07-2002 09:06 PM
