Old 03-22-2018, 07:27 PM   #1
lati_cz
michal
electrical question
I am building a metal trellis. There will be 6 posts (I beams 8x8"x11'). Design call for wood fillers on each "open" side of I beam. There will be approx 3/8"+ space between metal and wood on both sides, LED strip light will be attached at the back of the beam and light should shine through, see sketch.
Electrician run 1/2" conduit from house to first Sono tube (trellis will be installed on concrete porch), then from first to second, from second to third etc.
It's up to me what type of light I install, it's is only decorative. What type would be the best? One or two LED strips per side? Or rope light? I do not have room for oversized driver at post, if driver will be used than must be in the house. I can fit double box. with cover at max.
My client is a amateur musician, the house has a top notch stereo system through the house, if there's a way to synchronize played music with colored LED lights.... would be great.
Thanks for ideas.
Michal
lati_cz is offline   Reply With Quote
Old 03-22-2018, 09:27 PM   #2
Check out Amazon for the LED light strips - they change color, beat with the music, have Alexa interface, old school remote controllers....
Old 03-23-2018, 08:45 AM   #3
zeaflal
Check the current draw for the LEDs you select. LEDs tend to be low voltage and higher current loads which implies a large wire size. You might want (need) a home run from the controller to each post. Just thinking that 1/2 conduit might be too small.
Larry
zeaflal is offline   Reply With Quote
Old 05-15-2018, 11:07 PM   #4
lati_cz
michal
Installation on progress. Setting posts was pita, zero tolerance for error. I just run 12/3 - it was about max for conduit in there and tight turns inside post holes. I will do some light testing on field and go from there....
Michal
electrical question lati_cz The Mud Box 8 05-22-2014 07:35 PM
Electrical Question oakview The Mud Box 10 10-04-2012 07:30 PM
Electrical Question Marge Tile Forum/Advice Board 9 12-01-2007 07:59 PM
Electrical question Dave Taylor Tile Forum/Advice Board 13 03-18-2007 01:23 PM
Electrical question Sonnie Layne Professionals' Hangout 38 07-16-2003 03:55 AM
