Old 03-20-2017, 10:19 PM   #16
pecymanski
CX,
The whole caulking thing has me confused because it does not seem logical to follow what everyone says to do. I agree with what you are saying on not putting caulk between CBU/Tub as well as Tile/Tub.
It seems all the caulk is doing is closing up the path of least resistance for any water that would get behind the CBU.
The ideal solution seems like:
1. No caulk between CBU and Tub
2. No caulk between Tile and Tub
3. The gap between first row of tile and tun would be minimal, 1/16 to 1/8.
Unless you were really trying, should not get any water up there. Water does not want to go up (Unless thru capillary action) and it would be able to dry out.
But like you mentioned, everywhere you look it says to caulk between tub and tiles. I came across only one other source which mentioned the weep holes. This was in the case you were using a vapor barrier behind instead of a liquid water proofing.
Paul
pecymanski is offline   Reply With Quote
Old 03-21-2017, 12:27 AM   #17
tatumjonj
I don't think it matters much if you're using a vapor barrier or liquid waterproofing, you still need to leave a place for any moisture that gets behind the tile to escape. That being said, if it's just a tub, I'd caulk and and forget it. If it's also a shower, I'd be inclined to leave weep holes in the event that water gets behind the tile. Just my 2 cents, I'm sure you'll get a few different opinions on the subject.
Jon
Old 03-21-2017, 09:23 AM   #18
Da Home Builder
Paul, read the disclaimer at the end of my previous posts.
Do whatever makes you most comfortable.
Old 03-23-2017, 06:08 PM   #19
pecymanski
Hello,
I have a dropped ceiling above my shower/bath. It was previously tiled.
I was not planning on tiling. Would DensShield work as a good material to place over the ceiling area for moisture protection. I looked at the Georgia Pacific site and verified it can be painted.
Could I use thinset to cover the screws I use to attach the DensShiled and then cover with a good primer and bathroom semi-gloss?
Paul
Old 03-23-2017, 06:25 PM   #20
rmckee84
If it says it good to go for painting then yes that should work, but I'm not sure you really want to cover your screws with thinset. If you do that you're going to have a hard time sanding it down. Use drywall mud to cover the screw heads, sand, prime, then paint.
Ryan McKee
Old 03-24-2017, 09:40 PM   #21
pecymanski
Thanks Ryan,
If I was going to tile the ceiling, would I be able to fill the chunks of backer board removed when tiles came out with thinset. Baiscally skimcoat the entire surface. Then let it dry and then tile as usual?
Paul
Old 03-25-2017, 09:12 AM   #22
rmckee84
Possibly, but I would start fresh. I wouldn't want to install over anything on a ceiling that could compromise the bond. Failure on a ceiling could mean more than just a broken tile...Tear it out and start clean, there's no reason to chance it.
Ryan McKee
Old 07-12-2017, 08:26 AM   #23
pecymanski
Niche - Grout vs Caulk
Hello,
I have completed the tiling of the shower and included a niche. I understand that the changes of plan are to be caulked. Does this hold true for the niche as well, or are the changes of plan grouted in the niche?
Paul
Paul
Old 07-12-2017, 08:34 AM   #24
Da Home Builder
I believe you mean changes of plane, rather than plan, Paul. You can change your plan any time you want with no filler in the gaps at all.
I do not caulk the joints in a shower niche, although the tile industry standards would require a flexible sealant there. I grout all such joints. You'll do whatever you prefer.
Old 07-29-2017, 02:07 PM   #25
rguyler
CX, I have always caulked joints where perpendicular planes meet with excellent success but cement-based grouts seem to always crack and fail in time. However, I am approaching building my first niche so curious if you just happen to treat this as a special case or do you always grout joints such as this?
Rik
rguyler is offline   Reply With Quote
Old 07-29-2017, 04:09 PM   #26
Da Home Builder
Not sure what I can add to that, Rik.
Old 07-29-2017, 06:11 PM   #27
rguyler
CX, my apologies for not being clear. My intention was to ask why you grout the niche joints rather than caulk them, especially as you say the standards dictate caulking in this case?
Rik
Old 07-29-2017, 09:19 PM   #28
Da Home Builder
I consider the spaces in a niche too small to worry about movement accommodation and I don't like caulking at all on any outside corners, so I grout everything in a niche with the occasional exception of glass shelves.
Old 07-31-2017, 12:51 PM   #29
rguyler
Makes sense. Thanks for the explanation.
Rik
questionable backer board installation elvira Tile Forum/Advice Board 8 12-23-2016 10:05 PM
Backer board installation question Confused in Cinci Tile Forum/Advice Board 7 09-22-2012 06:59 AM
Backer Board Installation gone wrong - Need Help! Boykin Tile Forum/Advice Board 7 09-02-2008 11:22 AM
backer board installation questions ? web drifter Tile Forum/Advice Board 2 03-24-2006 09:24 PM
Backer Board Installation thiggy Tile Forum/Advice Board 4 03-08-2002 08:33 PM
