Old 12-20-2017, 12:25 PM   #76
If you're going to lay it out like that, I would lay out some tiles with the joint you plan to use and double check the measurement from the shower floor to the window trim. You want to make sure you don't have a sliver at the window.
Old 02-27-2018, 02:37 PM   #77
MisterJJ
I didn't think about how the grout lines would look mismatched on this corner with the bullnose but I can't imagine doing it any other way. I'm probably over-thinking it.
Joe
MisterJJ is online now   Reply With Quote
Old 02-27-2018, 03:23 PM   #78
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
You've found one of the inherent puzzles with pre-made bullnose. There are others. I used to lament the lack of bullnose trim for many tiles, but as a result have changed the way I do things. A change for the better in my case.
A piece of Quadec or mitering the vertical corner would look best IMHO.
Peter
Old 02-28-2018, 09:06 AM   #79
MisterJJ
I see how mitering could have worked a little better but that ship already sailed. The field tiles on the left are already set. But Mrs. JJ looked at how I have it set up and says it looks nice, so I'm good-to-go.
And I see what you mean by "inherent puzzles", as I've found one on the other end of the tub. I was thinking of either method shown below. First one would have an odd grout line blending into the bullnose radius and the second one had good grout line but odd offset. I think the solution here is also mitering. But I think I'd have to keep mitering all the way around the two walls of the tub unless I just transition to a regular joint after the bullnose.
Joe
Old 02-28-2018, 09:46 AM   #80
Carbidetooth
Hmmmmm
Joe, I'd do the first one and might even cope the vertical tile to horizontal.
Peter
Old 04-17-2018, 12:43 PM   #81
MisterJJ
Just an update on my slow moving build.
I got the floor done:
Then I ran into a bit of a problem where 4 layers of Kerdi overlap due to the corners. I tried to keep it as thin as possible but it was still too much.
I had to grind the backside of the tile so it would sit correctly.
(tile is on right, which will go on wall on left)
Here's the end of the tile after grinding:
Joe
Newb tiling above shower RMack Tile Forum/Advice Board 5 09-19-2011 10:14 PM
News Flash! Not so NewB NewB says hello! ronbo1100 Professionals' Hangout 10 02-04-2011 09:10 PM
Newb Shower Questions etulfer63 Tile Forum/Advice Board 8 10-07-2009 08:46 PM
Newb looking to take it all on....(Schulter shower system) reilinjw Tile Forum/Advice Board 42 01-24-2008 09:09 AM
Newb needs help with custom shower Bert Tile Forum/Advice Board 9 09-26-2004 02:56 PM
