Old 10-13-2014, 06:34 PM   #1
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
Floating teak shower bench
Hi all!
I want a floating teak slat shower bench in my en-suite, similar to the one in the image (minus the hinge dealio). Do any of you have a source for hidden post type support brackets? It will be on a "free" wall, so no opportunity to brace it in a corner.
Any ideas would be muchly appreciated!
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Old 10-13-2014, 07:39 PM   #2
Normally they are lag bolted into the blocking, no ?
Old 10-13-2014, 08:31 PM   #3
eurob
tile and stone installer
eurob's Avatar
I suppose this would be a permanent bench , Adriana .
Custom built frame -- similar to suspended toilet -- would give you a better chance of having a floating bench -- supported only with hidden tubing -- . Size of tubing should reflect a safe weight margin.
Roberto
Knowledge -- something you cannot undo once you learn about it --
Old 10-13-2014, 08:43 PM   #4
lati_cz
michal
I did some floating shelves home. I used large lag bolts, drove into studs, cut off heads. Drilled slightly larger holes into wood, put some glue, slided onto bolts. I sat on it to test it, no problem..
Michal
lati_cz is offline   Reply With Quote
Old 10-13-2014, 08:56 PM   #5
eurob
eurob's Avatar
Those shower benches are seeing all kind of '' testing '' .........
Roberto
Old 10-13-2014, 11:08 PM   #6
GraniteGirl
Ms. Makita
Oh, sigh, Roberto...
Yes, it will be permanent and will have a twin brother that will "carry on" on the other side of the glass divider. Grand ideas, I know...
Figured there might be something in existence already. Did not really want to have something fabricated, but will probably have to. Biggest thing is that I do not want to see a triangle type bracing underneath. That would be too easy, OK?
I have naked walls right now (no drywall or anything, in case your mind wandered again ) so anything is technically possible.
Adriana
Old 10-13-2014, 11:47 PM   #7
dhagin
Based on what yer describing, I'd be gettin something that carries through the glass area fabbed outa SS.
dana
Old 10-14-2014, 06:19 AM   #8
You and Casper are fabricators. Fabricate something.
Old 10-14-2014, 08:24 AM   #9
eurob
eurob's Avatar
I was trying to be thorough , Adriana .
I prefer the stone benches more than the wood ones -- I know, cold to the touch is an issue -- , but I did a floating bench with Bianco Royale with flat bars inserts ......... short story , after few months it did start to move . It did feel solid at first , but we had to support it -- adding 2 vertical pieces -- with the same material to the floor . The flat bars do not work , without the triangle concept .
You would have to design -- fabricate -- the supports independent of the wood wall structure ..... meaning you don't want the bench stress to have a '' pulling '' effect on the wood members .
Roberto
Floating shower bench waderemco Tile Forum/Advice Board 11 09-08-2013 07:25 PM
how do you install a floating shower bench? Sassywarden Tile Forum/Advice Board 8 07-10-2013 08:02 PM
Teak 'Grates' for Shower Floor? gordonquixote Tile Forum/Advice Board 8 04-30-2013 03:15 PM
Floating Bench whowee Tile Forum/Advice Board 6 02-12-2013 11:05 PM
looking for a floating curved shower bench CustomTile Professionals' Hangout 12 10-09-2012 07:48 PM
