Old 01-05-2008, 10:42 AM   #1
jvl
Exclamation thin set mortar consistancy
hello,i seem to have a problem of getting the right consistency for mixing thin set(flex bond)i worked with concrete for some time and a drier mix is used.when i try to mix the mortar so it does not slide of the trowel and the thickness like frosting. that mix for me seems to be too stuff and hard to lay down and trowel easily. i find if the mix is a little wetter that it slides off the trowel it then goes on smoother.can anyone set me straight.thanks jvl
jvl is offline   Reply With Quote
Old 01-05-2008, 11:19 AM   #2
LGB
Tile Contractor -- Pennsylvania
The data sheet for flexbond says to use 5 quarts of water per bag. When properly mixed, troweled ridges will stand with no slump. This is what you are after. You don't want the mix to slump or run.
Leon
LGB is offline   Reply With Quote
Old 01-05-2008, 11:28 AM   #3
stullis
Flooring Installer
Adjust up or down with small amounts of water, it doesn't take much to change the consistency when you are close to what you want.
Scott
stullis is offline   Reply With Quote
Old 01-05-2008, 11:31 AM   #4
ddmoit
ddmoit's Avatar
Welcome to the forum, JVL. Please give us a name to call you by.
Here are some past threads on the subject:
http://www.johnbridge.com/vbulletin/...et+consistency
Dan - a DIYer in SE Tennessee
