Old 09-11-2017, 09:18 PM   #1
nbanta
Removing grout from really thin joints
I need to remove grout from extremely thin joints in a shower ceramic tile wall. The joint widths are mostly right at 1 mm (approx. 0.039 inch; less than 3/64 inch). The oscillating steel blade that came with my Ridgid Jobmax fits in the joints, but you can guess how long the teeth on that blade lasted. And it wasn't doing much to the grout even before the teeth got ground down to little nubs. This grout is pretty hard, and a utility knife just doesn't do the job. So I'm looking for a diamond or carbide blade that is thin enough to get in the joints. Could be for an oscillating or rotary tool. Or for a handheld grout saw, for that matter, but I have to do the whole stall (4-inch tile), so I'd prefer to use a power tool.
The thinnest blade I've found is a 3-inch Fein Starlock Segmented Diamond 216 saw blade -- but the width is 1.2 mm and I'm afraid it would just ruin the tiles.
I'm sure I'm not the only one who has had this problem. Does anyone know of a source for such a diamond or carbide blade?
Ned
nbanta is offline   Reply With Quote
Old 09-12-2017, 07:47 AM   #2
zeaflal
If you are near a Harbor Freight, check their multi-tool diamond blades. Donít know how thick they are, but since it is Harbor Freight you know they will be using as little diamond as possible. My take was that they did not cut too well so they removed soft (not fully cured) grout easily without scratching the porcelain tile.
THK has some thin cutoff wheels. Not sure how you would use them. Or check their other products. https://www.thk.hk/online-cart-dtl.p...&ssid=0&id=424
Larry
zeaflal is offline   Reply With Quote
Old 09-12-2017, 09:20 AM   #3
The thinnest one I'm familiar with is 1/16", which seems to be too wide for you.
You might just have to use the thinnest one you can find and do the best you can with it.
Old 09-12-2017, 09:40 AM   #4
Lou_MA
You'll need a dremel rotary tool. And I find the flexible shaft attachment handy. If you have a whole shower to do, I'd pick up 4 or 5 wheels just to have them handy. They wear out fairly quickly.
http://www.homedepot.com/p/Dremel-7-...-545/100346850
Lou
Lou_MA is online now   Reply With Quote
Old 09-12-2017, 09:29 PM   #5
nbanta
Larry, thanks for the suggestion about the THK wheels...maybe there's a way to mount that on an angle grinder?
Lou, that Dremel wheel looks like it might be my best bet. Blade thickness / kerf is 0.04 inch according to Dremel.
Does Dremel make a 90-deg head to improve the handling and ergonomics?
Ned
Old 09-13-2017, 04:14 AM   #6
The flexible extension is the better bet.
Old 09-20-2017, 04:58 PM   #7
Mr_Stop
Home Remodeler
I have used the Dremel MM502 blade on my oscillating tool on thin grout lines. It states it's for 1/16", but it seems smaller as other 1/16" makes were too big. If it's a large job, you may want to pickup a couple as they don't last very long.
https://www.amazon.com/Dremel-MM502-...+removal+blade
Brad
Mr_Stop is offline   Reply With Quote
Removing Grout thin joints Jsmallberries Tile Forum/Advice Board 13 03-19-2017 05:32 PM
removing thin grout lines speculative mason Tile Forum/Advice Board 7 08-12-2014 06:23 PM
How much thin set to use at the wall joints dsib Tile Forum/Advice Board 13 06-17-2011 08:32 AM
Removing dried Thin-set from tile joints ataylor Tile Forum/Advice Board 4 06-12-2006 11:56 AM
Is it possible to thin a latex caulk for sealing thin joints? rtl_airfoil Tile Forum/Advice Board 3 11-23-2004 05:12 PM
