Old 09-10-2017, 01:56 PM   #1
Loui
Vanity subfloor or finished floor?
Hello all,
I would like to know what the standard practice is regarding bathroom vanities. When I pulled mine out it was attached to the subfloor. Mudbed and tiles were laid around vanity. I guess what I'm asking is should I install my vanity on the subfloor or finished tile floor.
Lou
Loui is offline   Reply With Quote
Old 09-10-2017, 03:21 PM   #2
Hi Lou,
It can be done either way. Since you pulled it out I think you should do the tile floor and set it on top.
Old 09-10-2017, 06:33 PM   #3
The vanity's height will be low if you don't install it on top of the tile. Plus, if you decide to remodel just the fixtures...you'll be stuck with trying to find a vanity that is exactly the same size and shape...that can be hard, and limiting. At a minimum, tile under at least the edges so it is properly supported.
Old 09-10-2017, 06:41 PM   #4
Loui
Thanks guys. The lower height might actually benefit us since we have 2 little ones. But john what you said makes sense. Might as well do it right and tile the whole room.
Lou
Old 09-10-2017, 08:21 PM   #5
They grow pretty fast. A step stool isn't a bad idea for when they're small.
Old 09-11-2017, 06:28 PM   #6
Loui
Ain't that the truth!
Lou
Old 09-12-2017, 06:06 AM   #7
RichVT
Vermont Remodeling Contractor
It seems to me that probably 90% of vanities available today are on feet or otherwise open on the bottom so that you have to tile under them. One of those design trends that I don't understand.
Rich
RichVT is offline   Reply With Quote
Old 09-12-2017, 09:58 AM   #8
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
C'mon Rich, dust bunnies need a place to live, too. It's a fair housing issue!
Peter
Old 09-12-2017, 01:01 PM   #9
Some people remodel once in a lifetime...some do it on a regular basis. If the remodel doesn't touch the tiled floor, you can have some big issues if your new vanity is slightly differently designed. Most of them aren't huge, so tiling underneath isn't a huge cost. As to feet on them, not everyone is good at keeping the tile perfectly flat, and feet, especially if they are adjustable, make it much easier to get things to sit flat and level. If you always change the floor tile on a remodel, it probably doesn't matter much. Second thought...the heights of cabinets became somewhat standardized on the height of a typical woman in 1954...people are taller today, and that's one reason why vanities are available in taller sizes without going custom. I'm tall...I like it higher!
Kitchen Floor - Subfloor to finished tile Shaver Tile Forum/Advice Board 6 01-27-2010 12:29 PM
Floor Tile or Vanity First? Nick_nack Tile Forum/Advice Board 7 05-10-2009 12:47 AM
height of finished floor tyl Tile Forum/Advice Board 23 02-28-2006 10:39 AM
Drywall & finished floor: height? TruckeeTrout Tile Forum/Advice Board 4 07-17-2005 06:06 PM
Floor finished!! lowella Tile Forum/Advice Board 2 04-30-2002 05:38 PM
