Old 09-08-2017, 06:24 PM   #1
Govinator3
Small Entryway substrate question
Hi everybody,
I have a small entry way, joists are 2x6 fir spacing 16 oc and unsupported length is 6' 3". Deflectolator gave me 1/697 with a 6.5' span. Im going to be installing a marble basket weave mosaic 1"x2" pieces.
Current subfloor is 3 1/4" x 3/4" TG pine flooring. Im wondering what my minimum thickness solution will be without ripping up the existing subfloor. I want to just slap nobleseal cis on top the subfloor but im pretty sure thats not gonna fly.
Let me know what you guys think.
Thanks, Mike
Govinator3 is offline   Reply With Quote
Old 09-08-2017, 06:49 PM   #2
rmckee84
Minimum I'd go with would be 1/2" ply over what you have. But I'd be more inclined to pull the boards and start fresh.
Ryan McKee
Old 09-08-2017, 07:05 PM   #3
Govinator3
Thanks for the input, in this situation 1/2"ply over 3/4" t&g could i tile directly to the plywood or will i need membrane or 1/4" cbu?
Old 09-08-2017, 07:21 PM   #4
Welcome back, Mike.
Your subfloor does not technically qualify for a tile installation directly to the top layer of plywood, but you can tile to whatever you like. I'd recommend you use a CBU or membrane of some type over your subfloor before tiling. The NobleSeal would be a good choice.
Old 09-09-2017, 04:15 PM   #5
Govinator3
Thanks CX,
I put my order in for noble cis today, its a bummer that i cant find someone who carries it in stock. I want to make sure i get the screw spacing right. Is 6" on the edge and 8" in the field correct? I assume I want to miss the studs as well? I wont be glueing it down.
Old 09-09-2017, 06:05 PM   #6
That would all be correct.
Small entryway tile project concerns VTrider Tile Forum/Advice Board 21 05-11-2015 05:57 AM
Plan and Material Advice for Tiling a Small Entryway cycad Tile Forum/Advice Board 0 04-20-2012 04:21 AM
Tile and hardwood in small entryway Lew Tile Forum/Advice Board 3 10-31-2010 09:13 PM
Small Entryway Project geektb Tile Forum/Advice Board 9 07-02-2010 08:37 PM
Tiling small porch/entryway questions wrx4sabelle Tile Forum/Advice Board 4 10-29-2006 07:04 PM
